    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by JoeHarris View Post
    Check this out if you haven't already- shapertools.com
    I saw this about two years ago and was quite amazed but it was only 2 axis then. I can see limitations though for instance it has the limitation that it has to have the tape all around the part you are cutting therefore you won't be able to cut say within 150mm of an edge of ply. But good idea in general and I can see some good applications for it.
    Edit Doddy The tape price is on the website
  1. Hand held laser cutter
    By Robin Hewitt in forum Tool & Tooling Technology
    Last Post: 24-10-2013, 06:05 PM
  2. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  3. MIT Students Hand Held CNC Router
    By mekanik in forum Marketplace Discussion
    Last Post: 26-09-2012, 12:49 PM
  4. NEW MEMBER: want buy new or second hand cnc
    By buildwood in forum New Member Introductions
    Last Post: 20-10-2011, 05:36 PM
  5. Convert Wood Lathe from hand held tooling
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 14-02-2010, 11:53 AM
