    ok thank you very much to everyone anyway
    Why not wire the full part profile then slice?
    Hold slices in softjaws in zero point system to perform any cnc operations.
    Finished.....
    The description is unclear but it sounds like some of the jobs are forgings being machined to finished size?
    Its not very clear what you are doing exactly, obviously is one thing machining 200mm thick part or 10mm thick part. But from what i have seen and know- what you are doing is done usually either using a vice and parallel plates below part, either 2 piece vice for long parts, parallels if needed and a combination of screws and clamps.
    Skimming flat on mill is achieved by fly cutter, for your case best would be custom heavy duty fly cutter so you cut at once as much wide as possible. meaning made so that is reinforced with disc.
    It is clear what hoezap is doing. The only way to really speed it up is change the process. He is already wiring. Wire the whole job. The speed increase is seen when the part is sliced...
    Quote Originally Posted by Billythefish View Post
    We bow to your greater knowledge ;-)
    lol... thanks! its nice to be appreciated
    Maybe hoezap can post some pictures to make it even clearer...
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    So wiring gives a better surface than machining?
    My interpretation, is they're surfacing both sides of the plate, but I'm not sure if the wiring is being done before or after the surfacing...
    No it's not cleat at all.!! . . . . Where does he say he slices the part with this fixture.? . . . Your assuming this.!
    To me it sounds like they are Wire cut to rough size and he's doing the Finish passes.? . . .But this isn't clear.
    My thoughts exactly, and my humour was lost on the expert
  1. Delcam 2016 demo version or price... pleeeease heeelp!
    By hoezap in forum CAD & CAM Software
    Last Post: 01-05-2016, 05:27 PM
  2. RFQ: RFQ: Very Simple Machining of Two Aluminium Parts Required
    By biketrialsdave in forum Projects, Jobs & Requests
    Last Post: 15-12-2015, 12:01 AM
  3. scm tech 95l cnc machining centre User manual or parts lists
    By george uk in forum SCM Group Routers
    Last Post: 28-04-2015, 08:18 AM
  4. RFQ: small machining job??
    By Wobblybootie in forum Projects, Jobs & Requests
    Last Post: 25-02-2011, 01:04 PM
