Page 1 of 4 123 ... LastLast
    Hi All,
    I need some guidance on electrical safety of products rules. I have made a lighting base for a glass sculpture. It is a sealed LED driver and a 20W LED chip on a heatsink. There is a fuse in the mains side and the mains cable and switch are purchased prebuilt. The cable is with an earth wire and the driver is earthed to a common point on the terminal block, which is connected to an aluminium base plate. I cut the base plate on CNC and there are plenty of ventilation holes, but strategically placed so that it is difficult to reach a mains voltage through them. The sculpture base is either bronze or cast iron and it has the base plate bolted to it. I will have the finished units PAT tested, but I am wondering if there is any other official process I have to go through before they are offered to the public.
    The pictures attached gives you an idea of the bases, but one pic was of a failure of the resin embedding of the glass, so doesn't show the base underneath. The second one was a brief test of the lamp.
ID:	19117Click image for larger version.
    Cheers,
    Rob
    If you can poke any household item through a vent hole and get at mains your product liability insurance might not pay out in the event of a child poking a straightened paperclip through a hole.
    Most current products use strategically placed mylar or other physical shielding to make access to mains impossible without making a real effort to cause damage,
    - Nick
    Ta Nick,
    I will put a 3D printed box round the terminal block. I take your point about product liability insurance.
    Rob
    Hi All,
    Cheers,
    Rob
    The answer is yes. If it can be plugged into mains and not fed through a commercially available power supply with low voltage then you should not continue with this idea, unless you can certify the product and know what you are doing, which you obviously don't. Even at low voltage there is a risk for causing fire if the used material is wrong, or you make a design error, so even if it is fed with an approved PSU you can still be liable. The regulations concerning electricity are not just some rules and regulations, but law, so breaking those are pretty serious. If your product can't, or won't be certified to follow the regulations then you are not allowed to sell, and if you do then you are taking huge risks. All those rules and regulations can't be explained in a few words on an Internet forum.
    Now, it is no secret that I am not a UK resident, but I am pretty sure your regulations are just as stringent as ours here in Sweden.
    Good luck.
    It's covered in this -
    https://www.gov.uk/guidance/electric...sponsibilities
    You'll need to read the attachments too for the relevant information, I don't assume that smart people can't read and learn things they don't already know! ;-)
    I'd look at incorporating a thermal fuse into the power feed such that excess temperature (you'll have to research and determine that) will cause power cutoff, also consider crimped tubular terminations for the mains wires at the connector block.
    Regards,
    Nick
  6. The Following User Says Thank You to magicniner For This Useful Post:
  7. #6
    Thanks Nick, I will look through the site and see what is relevant to my glassblower friend.
    At the moment, he produces an item http://www.stuartakroydglass.com/new...s/?galAlbum=44 which is a glass sculpture in a solid steel base. His idea was to light it from below with a fairly powerful LED chip. We are at a very early stage in development, with one working prototype. It has to be soak tested to see how the temperature rises on the LED, and to see if the driver is suitable etc.
    We hope to get some to show at a Craft Fair in London in 4 weeks time. This will be to gauge interest in the idea. If it flops - well - so be it. If it shines out then we will go further.
    Nick - thanks for your sensible input, when I have made a few more bases, I will post some pictures of the innards.
    Cheers,
    Rob
  8. #7
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Rob Have you thought about a 12V or 24V led and feed it from a commercial power brick CE aproved
  9. #8
    Yes, but couldn't find a suitable one. The driver we are using on out test rig is this one http://www.ebay.co.uk/itm/2015292070...%3AMEBIDX%3AIT and it has CE marking and IP65 printed on it (???).
  10. #9
    Can you buy one that is CE rated?
    This might be a good read: http://www.meanwell.eu/ExclusivePDF/...OVALS-NOTE.pdf
  11. #10
    Rob,
    I didn't make it clear but my reasoning for the thermal fuse is to use one rated above the temperature which the light unit might reach in a very warm room under normal operating conditions such that the power would cut before anything got hot enough to melt or burn,
    Regards,
    Nick
  1. Advice needed on everything
    By chrisjames in forum General Discussion
    Last Post: 11-11-2015, 11:40 PM
  2. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  3. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  4. Electrical whizz needed :)
    By don_jarr in forum Motor Drivers & Controllers
    Last Post: 23-06-2012, 08:10 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
