Thread: help needed with breakout board
Hi, yes I did that.i found a video on you tube that went into detail of wiring the breakout board and what to check. The e stop was in the check list.thanks again Michael
06-09-2016 #2
Terry did you get the PC with machine or have you installed Mach on another PC.?
If it was working when bought it then just moving shouldn't hurt the BOB. Only takes one wrong setting in Mach3 and nothing will work. Esp when using the Parallel port which this BOB clearly is using unless plugged into another External motion control board.?
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
Breakout board recommendations
By GND in forum General ElectronicsReplies: 15Last Post: 15-07-2015, 07:24 PM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
FOR SALE: PMDX-122 Breakout board
By IN-WondeR in forum Items For SaleReplies: 0Last Post: 14-12-2011, 04:05 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
