06-09-2016 #11
06-09-2016 #12
Yes but inexpensive until it comes to finding a plc capable of stepper control, although i must admit i have only used the larger more expensive units in the past - do you know of a cheaper PLC?
06-09-2016 #13
http://www.zappautomation.co.uk/elec...nit-23609.html
Its the last one, so once gone the price goes up.
if you want to set the speed from a 0-10V, you will need another plc, but you can set the speed in the program.
If you have not programmed plcs before you are best getting someone who has to commission the system.
I know an engineer who can do this, but he will charge you.Visit Us: www.automationshop.co.uk
06-09-2016 #14
Also if you want to add a HMI so you can set the speed and move distance from a touch screen you can also do that with one of the HMI we sell.
06-09-2016 #15
Thanks Gary that looks a nice little unit but yes we will need to vary the speed somehow. The HMI is a good thought but is really not needed here, a simple pot will do the job, especially as the HMI really pushes the cost up.
06-09-2016 #16
Ok good luck, but if you are using a simple speed control. then you may have issues with it stalling if you set the speed too high and just enable it.
We also have a stepper driver that can run with a +/-10V or 0-10V and has limit inputs and a number of other features as well.
http://www.zappautomation.co.uk/elec...60-aa-000.html
or if you want closed loop and +/-10V like a servo.
http://www.zappautomation.co.uk/elec...or-driver.html
06-09-2016 #17
Thanks, i'll keep looking for the right solution. A simple speed control won't work - it needs to ramp up and down, this is the bit that makes it more complicated.
06-09-2016 #18
+1 for Cropwell's suggestion: An Arduino coupled with a stepper driver would walk all over this.
06-09-2016 #19
Yes i would agree but having seen the code, i have not got much inclination to start learning a new language now, it would need to be written and programmed for me and i feel that would push the cost up.
I can handle visual basic but it looks more like C++ or similar and makes no sense at all to me i'm afraid.
06-09-2016 #20
The members of this forum have given you the best options and you're not happy with those options.
So pay lots more money for someone else to be bothered, it really is that simple!
Your VFD option on another forum will work great, with the required sensor and some really expensive control kit :-)
Stepper motor I.D anyone?
By Nthkentman in forum Machine DiscussionReplies: 2Last Post: 11-05-2015, 08:03 AM -
FOR SALE: 3 Axis CNC USB Motion Card Mach3 200KHz Breakout Board For Stepper/Servo Driver
By dudz in forum Items For SaleReplies: 0Last Post: 03-01-2015, 03:40 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM
