    Good day
    Sorry in advance if this is a thread that pops up regularly?! I'm fairly new to CNC and Forums for that matter (Hi!)
    I'm running my first flat pack carcassing project in 18mm melamine faced chipboard on my machine soon and am just after a little advice....
    I've got a 7.5kw spindle capable of running a top speed of 24000rpm
    I'll be using an onsrud 1/2'' compression cutter.
    I have done some test runs in material at general manufacturers guide line feed and speed rates with varying success - I understand there is always an element of trial and error but I always seem to get break out on the upper face of the melamine.
    I now understand that the first portion of the cutter is up-cutting so that needs to plunge and cut past the top layer of melamine.
    What I have no real idea of is how fewer passes I can get away with and perhaps this is ultimately why the compression cutter wasn't getting the results I require?
    Can I cut 18mm in one?
    Or is it best to do say 1 pass with an offset and then final pass cut profile to desired dimensions.
    Sorry I know this is perhaps basic stuff to many.....I'm teaching myself as much as I can?!
    I appreciate any help and give thanks in advance
    cheers
    Nick
    It will work in any way you use it, but it's really meant for 1 full cut into material. Its a trickier cutter to use and IMHO a finishing pass is needed for any hard part /melamine layer in that case/ whatever the cutter. I know that from cutting phenolic sheets with melamine layers both sides. It is very challenging to obtain a perfect not chipped edge.
    Here is a discussion between people doing this all day which confirms what i say http://www.woodweb.com/cgi-bin/forum...pl?read=772857
    It will work in any way you use it, but it's really meant for 1 full cut into material. Its a trickier cutter to use and IMHO a finishing pass is needed for any hard part /melamine layer in that case/ whatever the cutter. I know that from cutting phenolic sheets with melamine layers both sides. It very challenging to obtain a perfect not chipped edge.
    Hi
    Okay, cool - thanks for the advice and link. I'll trial cutter with one deep offset pass and then a 'through cut' with final pass.. the guys in the link mentioned doing final cut in reverse (conventional cut?) is this of great benefit to edge finish and reduce melamine chipping etc?
    Whether you do it in one pass or two (onion skin) depends on the size of the part, and the quality of your vacuum hold down. (you do have a vacuum table, right?)
    Do NOT climb cut, as it will leave a rougher edge. Conventional cut always with melamine (and most wood products).
    Feedrate of 15-18m/min, and 16,000-18,000 rpm.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    [QUOTE=Ger21;98845]Whether you do it in one pass or two (onion skin) depends on the size of the part, and the quality of your vacuum hold down. (you do have a vacuum table, right?)
    Gerry
    Thanks for the reply. Invaluable knowledge and massively appreciate the advice.
    Yes I do have a vacuum table (sorry cant find spec...) and am machining large parts (kitchen carcass panels). Had spindle speed about right but feed rate less than half what you are suggesting
    one last question (sorry) regards cutting direction - will I gain anything (mainly cutter lifespan?) from running an initial offset 'climb' pass before doing final dimension profile as a conventional (melamine + most wood materials) ?
    thanks again in advance
    Nicko
    Imo, no. Conventional cutting will give better tool life.
    By doubling the feedrate, your tool life should also nearly double.
    Gerry
    The reason that some people do a climb pass first, followed by conventional, is this.
    At high chip loads like this, the cutting forces are pretty high, and with a conventional cut, will tend to pull the tool into the part, resulting in a slightly undersized cut.
    This can also happen when onion skinning. The first pass will pull the tool into the material, but the final pass will be more accurate, and leave a small lip on the bottom of the part.
    By doing a climb cut first, the tool is actually pushed away from the part, which leaves a small amount of material for the final, conventional cut.
    But the climb cut won't cut as clean, especially as the tool starts to wear, so it may leave chips that won't be removed on the final pass.
    Gerry
  1. CNC Vinyl Cutting
    By Leadhead in forum Workshop & Equipment
    Last Post: 24-03-2016, 09:09 PM
  2. working with only low grade chipboard
    By steven in forum Woodwork Discussion
    Last Post: 28-11-2015, 12:33 PM
  3. FOR SALE: Pair of Thorex Nylon Faced & Body Hammers in size 32mm & 44mm
    By Solihull1 in forum Items For Sale
    Last Post: 14-08-2014, 07:07 PM
  4. Cutting Ply/MDF
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 02-10-2013, 01:59 PM
  5. Cutting Fluid
    By Web Goblin in forum Swarf & Chip Management
    Last Post: 12-01-2013, 09:31 PM
