    I bought one a few months back but I haven't been able to set it up yet as I've had a number of home maintenance disasters to sort out. I bought a bare bones 6040 without any of the electronics from ebay (RATTM Motor). The kit comes semi assembled and all the critically aligned stuff comes already pre-assembled. It looks fairly decently finished but the overall impression is that it has been designed to be just about adequate to cut soft materials like wood and plastics routinely and aluminium at a push on the odd occasion.
    Professionals and serious enthusiasts here quite rightly point out that it is not an adequate machine for serious work, but for a complete noob like me seeking to teach myself CAD, CAM and CNC machining from scratch, the 6040 looks like unbeatable value. I can always flog it off on ebay for not too big a loss if I outgrow it.
    I've bought good stepper motors (3.1NM) and drivers (AM822) and I am going to build the electrics from scratch with a view to retaining them for a machine upgrade in future should the CNC bug bite. I decided to go this route as the biggest cause of dissatisfaction and problems with these machines by a large margin is the electrics. I would suggest looking at this option seriously rather than buying one with the OEM control box. You will be able to sell it off easier and recover your costs even if it means spending a little bit more.
    The vendor sent the item fairly promptly and it came well packaged. I haven't needed any after sales support but I doubt you would get any apart from a replacement for obvious damage.
    Quote Originally Posted by nirmal View Post
    Yeah I'm not doing serious work, besides I know what the guys say about them I've been around long enough lol But if you manage your expectations then you can get very close to want yo want :) Thanks for the info
ID:	19152Click image for larger version.
ID:	19153Click image for larger version.
ID:	19154Click image for larger version.
    Ralph Waldo Emerson
    Rye's Avatar
    Lives in Sheffield, United Kingdom. Last Activity: 16-02-2019 Has been a member for 9-10 years. Has a total post count of 50. Received thanks 4 times, giving thanks to others 0 times.
    I bought a 6040 with a 1.5k ER11 spindle, black box (not the blue one) with a SMC 4-4-16a16b fitted(no need to connect to a PC.) It cuts plastics and both soft and hardwood easily. It also cuts aluminium reasonably well. That said, I've had a few problems with mine: limit switches breaking, limit switch wires breaking, a screeching y axis(caused by bolts under the bed coming loose) and bits n pieces coming loose on the z gantry. The pump switch in the box has also stopped working. And the pump that came with the machine could wake the dead.
    If I knew what I know now, and if it wasn't for my poor health and money problems(something always crops up making me dip into my savings), I'd replace the machine in a snap. All that aside though, I do enjoy using the machine. It's not that bad TBH (it's like a bridge camera pretending to be a DSLR). If you do buy one, I'd look around. For that sort of money you may get one with a 1.5k WC spindle.
    Bought a Chinese 6040...if only I'd known better :(
    Quote Originally Posted by Rye View Post
    Totally agree , I don't do serious stuff. Though if I can make enough money with things that its capable of making (with a little post work) and save up enough money, I would buy a decent one in a heart beat.
    Ralph Waldo Emerson
    I bought one over Christmas, 6040 with:
    • old-style (blue box) parallel port controller (24v PSU and TB5650s on a card)
    • 800w air cooled motor
    • Huanyang 1.5kW VFD spindle controller
    It was the bare minimum that you could call a CNC router, no limit switches and kept missing steps on anything faster than a crawl. I replace the controller with
    • GRBL on Arduino Uno
    • TB6600s
    • 36v PSU
    • Some limit switches NO and series wired as pairs for X, Y, Z
    Which I would call a marginal upgrade - I wanted the 6600s to take the extra voltage of the 36v PSU. I used bCNC to pump the G-Codes.
    Than I milled some stuff: first some air, then some polystyrene, then some MDF (a spoilboard then a dust boot), then some phenol plastic.
    Not bad results, quite impressed with what you got for the money TBF.
    I was building up to milling aluminium (I also have a 1.5kW spindle waiting in the wings) but accidentally milled the top off a steel bolt (holding down my spoilboard) and by the time I hit the Big Red it had made a pretty good job of carving a slot in the bolt head. So now I'm not so scared of trying that aluminium
    So yeah, with perhaps a few cheap mods (TB660s @ £6.50 a pop etc.) I'd say I'm well pleased with it so far!
    -Phil
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Oops, I just bought this....
    By irving2008 in forum Marketplace Discussion
    Last Post: 24-08-2012, 10:58 AM
  3. Well I bought one off ebay..
    By Fivetide in forum Marketplace Discussion
    Last Post: 23-08-2012, 02:28 PM
  4. eBay's Latest Changes for Sellers !
    By Lee Roberts in forum Marketplace Discussion
    Last Post: 28-07-2009, 12:53 AM
  5. Woo Hoo, I just bought me a mill :)
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 05-11-2008, 07:43 PM
