	10-09-2016 #1
Hi just wanted to ask if its possible when purchasing steel tubing you can have plates welded to both ends with requested tapped holes? also after reading from an old thread on here i seen some people say to never rely on 3d drawings when it comes to actually putting the pieces together in real world. what i mean is if i can get steel plates made and drilled from my drawings and then welded onto the steel tubing directly from the same company would i expect problems matching those holes to the rest of the gantry?
sorry if this sounds confusing and thank you in advance
BUILD LOG: Desktop size steel welded router 3 axis
By Tom J in forum DIY Router Build LogsReplies: 84Last Post: 28-03-2017, 09:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
RFQ: 8 off steel plates required, drawings attached
By TonyD in forum Projects, Jobs & RequestsReplies: 1Last Post: 10-05-2014, 10:26 PM -
Tapping Delrin for M10 threaded rod - doable?
By HankMcSpank in forum Machine DiscussionReplies: 7Last Post: 02-02-2013, 12:31 AM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM
