13-09-2016 #7
I think you are missing the point that the most imprecise part in a machine is not the drilling but the welding. I am a maniac and it took a lot of time, so 1200x 600 machine i weld under 1mm in all directions. But it takes time, a lot of time to align and wait for heat... My big machine i did alone by myself and it was even more difficult. All is ~1mm plus one mistake at one end where ~2.5mm. How did i know- judging from channel depth when pouring the epoxy. Epoxy could be only 5mm deep and 3mm min, so machine must be precisely welded.
I doubt where i live / Spain/ a local welder could do that. Have been working in construction so i had to mount fence, doors, etc.
So as a conclusion, if sb welds for you, you have to specify one priority, not seek perfection. If sb welded for me, the priority will be for the top side / under epoxy/ to be in one plane as much as possible. Gantry though i recommend to be as perfect as possible. Z must be perfect /if welded, that means hard stops or fixture/
Anyway, all this said , then what it means is weld the plates, but drill them when on machine and rails aligned. Otherwise all must be machined.
BUILD LOG: Desktop size steel welded router 3 axis
By Tom J in forum DIY Router Build LogsReplies: 84Last Post: 28-03-2017, 09:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
RFQ: 8 off steel plates required, drawings attached
By TonyD in forum Projects, Jobs & RequestsReplies: 1Last Post: 10-05-2014, 10:26 PM -
Tapping Delrin for M10 threaded rod - doable?
By HankMcSpank in forum Machine DiscussionReplies: 7Last Post: 02-02-2013, 12:31 AM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM
