Thread: DIY 6040 CNC - advice required!
	11-09-2016 #1
Hi guys,
I am thinking of building myself a bigger CNC. I currently have a cheapo 3020, which has served me well, but it's time for something a little bigger. I initially looked at kits and was thinking of building an Openbuilds machine. The main reason being my lack of a machine shop to make custom parts, and I almost wanted something I could bolt together. As Jazz had done a stellar job on making me a custom panel, I emailed him about some custom plates. Being the wise owl that he is, he knew exactly what they were for and kindly steered me away from that direction. I am really glad he did, because when I costed everything, I realised that for the cost of the wheels, spacers, bearings and leadscrews, I could get some ballscrews and linear rails.
With that option out the window, it meant I have 3 options...
- Make the current machine bigger.
 - Buy a prebuilt 6040 frame
 - Design and scratch build something.
Option 1 would be the cheapest option, as I would probably just have to buy rails and a leadscrew for a longer Y axis, and re-use the current Y axis parts for a wider X axis. (It wouldn't be a 6040, but more like 6030 and would still have the unsupported X rails)
Option 2 is the easiest, but least fun and would end up with the same unsupported X axis rails.
So that leaves option 3, and being on a really tight budget makes it a bit more challenging. I hope I can re-use the electronics and motors from the old machine for starters. I have no idea what rating the motors are as they are unbranded. I only have the 3 cheapo stepper drivers that came with the original machine and they are rated at 2.5A.
So the first couple questions before I dive into design are...
Bearing in mind I would like to be able to do some light aluminium work, what the minimum size profile & plate thickness I can get away with for a 6040 size build with a frame design like this?
Would Hiwin 15mm rails be good enough?
Regards,
Les
	12-09-2016 #2
80x40 for the profile
15mm for the plates
Yes to 15mm linear guideways
.MeLast edited by Lee Roberts; 12-09-2016 at 08:40 PM.
The Following User Says Thank You to Lee Roberts For This Useful Post:
	14-09-2016 #3
	14-09-2016 #4
In fact, I'd use 90x45 or even larger. My current build is made up mainly of 90x45 and no regrets at all. Regarding the rails, I think it is in any case a good idea to install those on a plate, and not directly on the aluminum profiles. I am using 4mm thick aluminum pates between my (supported round) rails and the extrusions. Perhaps if I'd have flat 15mm rails I'd put steel plates between, not aluminum, but I think even aluminum is better than nothing.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
NEW MEMBER: Milling work required would appreciate some help and advice - New member
By reidy- in forum New Member IntroductionsReplies: 2Last Post: 04-05-2015, 10:21 AM -
Help required with desktop cnc build - cutting out the required plates
By alanb in forum OpenBuilds OX CNC MachineReplies: 0Last Post: 08-07-2014, 03:11 PM -
advice on software and machine required please.
By iamspuddy in forum CAD & CAM SoftwareReplies: 9Last Post: 18-04-2012, 08:14 PM -
NEW MEMBER: Hello everyone advice required please.
By Paul-in-Bury in forum New Member IntroductionsReplies: 1Last Post: 26-01-2012, 11:57 PM
