Thread: gantry weight
thanks boyan its an interesting thread so far :) i was originally going for nema 23's 3nm on a 2:1 ratio. i cant remember where i read it from but are servos alot more complicated to use then steppers? my actual goal is to get as much resolution as i can while keeping the machine nice and quick, i had in mind with the nema 23's running 2020 screws on a 2:1 rotating nut so i get some of the speed from 20mm pitch and resolution from a 10mm pitch. my dream goal was to have a resolution of a 5mm pitch but still have a really quick machine but ive learned thats not possible on steppers and im not quite sure yet if its possible on less expensive servos.
cheers
Ash
How much weight can 3.1NM motor lift? (as in Z axis)
By Noplace in forum Stepper & Servo MotorsReplies: 2Last Post: 20-04-2016, 09:42 AM -
Z axis weight
By DigiSoft in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 15-09-2013, 07:42 PM -
Dimensions and Weight of Denford Starmill PC Please
By cristec in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-08-2012, 07:02 AM -
Sieg X2 head weight
By pequod in forum Sieg Milling MachinesReplies: 6Last Post: 25-08-2011, 11:09 PM
