Thread: mach 3 scaling issue
14-09-2016 #7
Just completed the test.the tool pointer moved 56mm, so a little bit of adjustment needed.but this does not answer why the machine is cutting far to large.the fault must lay in the way mach 3 is reading the artcam software.could it be that the g code needs to be in a different format .....
Arc movement issue
By lukecnc2012 in forum Metalwork DiscussionReplies: 4Last Post: 09-08-2015, 07:15 PM -
Up-scaling CNC Sidewinder to cut 8x4?
By toby in forum Machine DiscussionReplies: 4Last Post: 11-05-2015, 09:15 AM -
In profile mode Mach cuts corners off? Shortest distance issue?
By marbles in forum Artsoft Mach (3 & 4)Replies: 16Last Post: 29-04-2015, 12:34 PM -
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Ref all home issue? A hand would be great just here!
By suesi34e in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 24-09-2014, 09:54 PM
