No need for rotating nut there!?! How long is the X travel? I have 1610 screw on my machine, with both sides rigid end supports/ made to mill aluminum/ and my travel is ~1300mm, ball screw length is 1520mm/ including end machining both sides for the fixed supports/
No whipping or whatsoever at 20000mm/min and 3000mms2 acceleration, though for the moment i run it at ~7000-10000 machining wood, which also is quite fast.
15-09-2016 #2
If you went for an I-Beam for your cross member you could increase it's rigidity whilst bringing the ball screw much closer to the line of the slides, losing the outrigger and increasing rigidity there too,
15-09-2016 #3
total ballscrew length is 1800mm and travel is 1300mm, only reason for rotating nut is incase of whip as im mostly cutting wood so 10000/min is my goal
Ash
15-09-2016 #4
just out of curiosity, when determining the z axis height do you measure to the collet?
15-09-2016 #5
BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
By Slixxor in forum DIY Router Build LogsReplies: 44Last Post: 29-12-2016, 02:57 AM -
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
By nobby in forum Items For SaleReplies: 1Last Post: 24-09-2014, 09:08 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
