Page 1 of 27 12311 ... LastLast
    HI,
    After being looking at various controllers at the end i decided to test some of the offline ones. Started with one of the cheap ones. As you can imagine it would be great to forget about Windows if possible. So i decided to overview it "officially" here, hopefully sb could find that helpful.
    DDSCV1.1, 3 and 4 axis. / note that in the 3 axis version you can not change any axis to rotational , but the 4rth axis variant, has a rotational axis option for A/
    Mistakenly bought the 3 axis version / if sb wants that one , PM me/ . I have read the MANUAl from page one to end very carefully and apart from some small questions all looks well.
    And yes, i will connect my 2 long axis to one of the controller axis or just one of them and control the other from the servo itself . Will see about that.
    Here was the most extensive info in English i found till now
    OK. So it arrived.
    -Price paid 165$ for the 3 axis version
    -nicely packed
    -looks nice
    According to me if one knows what he is doing it could be a perfectly self sufficient control for great price. It has spindle control, probing, software limits, separate axis homing, separate axis zeroing, etc.
    Instead of writing novels, i made a video overview of it:
    Part one, ~20 min introduction, basic functions and settings
    Part 2, running program test
    Prt 3 / still to film, when i have more time will set it on my big machine, connect all and see how it moves, homes and so on in real life, otherwise all above is pointless/
  2. The Following 12 Users Say Thank You to Boyan Silyavski For This Useful Post:
  3. #2
    Hi, could you open the case and get a photo of the PCB, I am very interested in seeing the difference between the 4 Axis, if any. There is no problem driving two stepper drivers from one axis. The X on my router has two motors and I use two separate drivers from the X axis signals.
    here is the photo of the board:
  5. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  6. #4
    Thanks, thats just the picture I needed.
  7. #5
    These controllers are going to be a game changer for the many people sat on the fence telling themselves CNC is too hard to get into.
    John S -
  8. #6
    These look great, what Lathe/Mill Post Processor is required to generate code for them?
    Most similar things I've seen claim "Standard G-Code" but then don't mention which easily available Post Processors produce "Standard G-Code" as all the PPs I've found have a manufacturer/machine/controller designation.
    Mach3 developers had the good grace to work close to a standard for a popular industrial controller rather than a paper standard to which no manufacturer quite adheres.
    Never underestimate the incapability of the masses, there's still all those scary wires to connect ;-)
    - Nick
  9. #7
    - Nick
    That's the big question before jumping to conclusions
    What i found till now:
    - Post processor for mach3 definitely does not work, as you could see in second video it runs away from the job coordinates. Who cares, me not. I could save my programs again in the proper format
    -It doe not recognise manual tool change code also. So jobs have to be split. Not big deal
    -Does not recognise G20 and G21, so program must be in mm to begin with. No problem so far.
    -Will run properly G code as of the Gcode and fanuc output from Aspire. Though program was simple. / See video2/ .
    As i have not connected it yet to a machine i can not say more. But there is a good chance that all goes fine.
    Does it support a Tool Changer/Turret etc. ?
  11. #9
    This is a basic controller. The much more expensive Chinese controllers not only do all but close the loop also, at least the most expensive ones, which makes them really industrial
    funny, i see now that it supports G20 and G21 but when i was testing it ?, so maybe i made a mistake somehow with the file. Will check again
    That's what it supports.
Name:	g code 1.PNG
ID:	19199Click image for larger version.
Name:	g code 2.PNG
    No and neither does Mach 3 or LinuxCNC without 3rd party boards and a load of tossing about.
    They are basically a cheap foray into CNC without a PC, monitor, licenses etc and all the Mumbo Jumbo that Mach and Linux entail.
    John S -
  1. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  2. FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
    By lateAtNight in forum Items For Sale
    Last Post: 24-06-2014, 03:41 PM
  3. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
