Page 23 of 27 FirstFirst ... 132122232425 ... LastLast
  1. #221
    Quote Originally Posted by AlexDoran View Post
    Ok i am really struggling to get my DDCSV1.1 to activate my spindle Via the Huanyang VFD, has anyone on here already done this successfully? I'm not sure on, and cannot seem to find any information about what signal the VFD is expecting on the FOR terminal in order to engage the spindle.
    Any help would be greatly appreciated.
    Alex
    I think all is self explaining from manual:
Name:	Spindle connect.JPG
    Only 3 cables you need. Ground is connected in the VFD as far as i remember
    Yes i figured it out. You have to wire it as the manual, however the VFD is slightly strange as you have to ground both the ACM & DCM (Analogue & Digital Grounds) to each other. A bizarre occurrence to me, not sure what the Chinese logic is behind it but it works. I can now control the M3/M5 commands and set the speed from the DDCSV1.1.
    Alex
  3. #224
    Sadly YouTube's closed caption translation feature reads like a Chinese written manual and I don't speak the language used :-(
    A written review to accompany the video might reach a wider audience?
    - Nick
  4. #225
    I like you fitted the controller it looks great. I seem to have an issue with mine now where; if i leave it powered down for long than 5 minutes or so, when i boot it back up, it doesnt boot first time, instead i get a long beep and the backlight of the display, if i switch it off and back on again it works perfectly, very strange.
    Alex
  5. In DDCSV2.1 change PNP inputs to NPN!
  6. #227
    Quote Originally Posted by foto-boss View Post
    Is there anyway to make the DDCSV2.1 work in inches rather than millimeters?
  7. #228
    Quote Originally Posted by Bubbles View Post
    There might be but My CAM allows me to swap between measurement systems so I can POST code in inches even though I work in mm.
  8. #229
    A few links to save others searching maybe: DDCSV2.1 doesn't yet seem to come up with UK ebay searches (still just the 1.1 version) but some 2.1 details and manual downloads are here and a USA ebay listing is here.
  9. #230
    I use CAMBAM. It lets me change between inches and mm.
    I already have many files created in inches. Changing them to mm instead of inches seems to make no difference.
    When I try to run one in inches it seems to run in mm instead of inches.
    My spindle is calibrated to move 25.4mm to get 1in of travel, so assume if I increased my numbers 25.4 times I would get what I want. Except I don't want to go through my files and convert them manually.
    Am I missing something to get files to run at a 1 on the display = 1in ???
    Thanks for your responses so far guys!
  1. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  2. FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
    By lateAtNight in forum Items For Sale
    Last Post: 24-06-2014, 03:41 PM
  3. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
