    I can see these controllers filling a niche market.
    They are going to appeal to the home build user with one of a couple of machines. Probably smaller machines that don't need the bumph of having a PC and monitor connected.
    As Jazz says you will still need a PC for doing programming but that doesn't have to be in the workshop.
    The PC could even be a Mac running Fusion 360 and in this case that computer won't run the machine anyway.
    As long as all you need is 3 + 1 axis, no slaved axis or provision for tool change then these will run fine. Especially if all you want to do is produce parts.
    Anything else then at the moment the PC is king but this will change as does most things. Speaking with Art Fenerty the other week he mentioned that there have been issues with Mach 3 running on later computers not being able to read some of the system files as late machines don't use these files and they don't bundle them with them.
    Not an insurmountable problem at the moment but it could be later on.
    Mach 4 is a work in progress and it makes me wonder if it will ever be a plug and play program given that it can't stand on it's own and requires a 3rd party controller to run and Brian has no control over these.
    Because my current area of interest is lathes and threading at the moment I have done a lot of research. With mach 3 CS Labs can thread, it's the only one that can but the thread always has a big run off groove which on small threads is not acceptable. They say Mach 4 if they do a plug in will be the same.
    Mach 4 can now thread with the Pokeys 57CNC and Dan Maulch over in the States has literally spent 6 months of his life getting it to run. Why ?
    Why hasn't this been done by Mach4 working with Pokeys and released by them?
    This was one reason I went with the NEW990TD-b because it can thread straight out the box and was the best option for me.
    Note the ME bit because we all have different agenda's.
    There isn't one controller option out there be it PC or stand alone that ticks all the boxes. Eaach has it's own niche market and you have to look and see what you want and what's available.
    These DSCV controller are cheap and they will fill a gap in the cheap end of the market, it's that simple but they won't do everything and if you can accept that and live with it then I can't see any problems.
    John S -
  2. The Following User Says Thank You to John S For This Useful Post:
  1. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  2. FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
    By lateAtNight in forum Items For Sale
    Last Post: 24-06-2014, 03:41 PM
  3. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
