    I would call this "customization", as i have no words to describe the original boot screen!!!
    But i'm working on a very good graphic, so it will make sense then. This was just a trial.
    A big thank to Benedikt for his contribution about the firmware, we hope to make this one "open source" soon.
  2. The Following User Says Thank You to Merlin201314 For This Useful Post:
  3. #2
    Quote Originally Posted by Merlin201314 View Post
    Yeah great work you two are doing on this, I read the mad modder thread on it last night.
    I wonder if Boyan has seen it yet ?
    Mmmhhh, don't know , maybe not yet, in the meantime this is the better one, Benedict is going to include the design as default if possible, let's see how is going on in the next few days...
    Cheers 🍻 Click image for larger version.
    Sended by my tapatalk
  5. The Following 2 Users Say Thank You to Merlin201314 For This Useful Post:
  6. #4
    The modding this controller needs is the following:
    -make A to be slaved to Y / i still dont know if that is not originally done as there is a place where you say if A is B, whatever that means even if degrees does not change to mm/
    -make the squaring of gantry YA
    -read the M06 command
    -reassign the Limit switches inputs for other purposes . This controller only needs 4 home inputs, not 12. Connecting the limits together on each axis , like is normally done by DIYers
    Who is Benedict?
    The A axis slave reference can be set as A/X, A/Y, A/Z in my controller,
    A or B axis selection is not clear in the software, but at this point everything is possible with the chinese.......
    "circ" should mean mm in translation, as the circumference is measured in mm, not in degree,(rotation=degree)
    Benedikt is the Mistery man :-)
  8. #6
    I discovered that i have a problem with small carvings and very fine details. I tried 2 times to carve a stamp from aluminum ~30mm diameter, X and Y started slowly to loose position. Lowered the acceleration from 3000 to 1000, did a dry run also.
    Same problem persists. .
    Now the question is: the controller??? or the servos need further tuning??? or i have to slow further things down, which i dont believe is the case. I remember i bumped up servos quite much to be responsive via software and even 3000 accelerations and more than 10000 mm/m speeds on objects like 200x200cm there was no problem at all. Checked initially the machine, does not seem to have sth loose.
    Any ideas??? Could that be the small lines? Exported v carving file as arcs also, same again. Thinking about it it looses both X and Y and moves slowly in diagonal on every step down of the Z is visible. At the end of tool path controller shows same machine coordinates as on start 0.
    Should i try to find the look ahead in the controller and make it bigger, i was thinking of disabling drawing the tool paths?
    i don know what exactly to do now except bump more the servo response and see what happens
    If there is option to change Step edge ie: Active hi/lo then try this. You could be on the wrong side of the edge in which case you'll lose 1 pulse for every direction change.?
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  11. #8
    In the controller, in the last part of the machine parameter you can fond the "interpolation period", set it up at 0,005 and try it, change even the "screen refresh" at not less than 4000, otherwise the screen will slow the cpu, as it not equipped with a graphic card.(you don't need to watch the screen, watch the machine).
    Find even the "operating acceleration" parameter and set it up at 500mm is the diagonal interpolated acceleration try it and find a reasonable one for your machine.
    Is just a bit of thing to try, maybe it won't help you, but it worth try.....
    If you have servos, they are coming with resolver on the back, so your motors know exactly where and when they are at all time.
    So, even with strong acceleration they shouldn't loose position... Here the problem: is your Router ridgid enough? Because with long traveling and strong accelerations the structure has the time to stabilize in between the movment, with very short traveling the machine is going into a factor called "structural resonance" and "inverted motion", what that mean? It mean that the axis is called to travel in a direction, but due to acceleration and mass involved the underneath structure is going in the opposite direction, and in a very small piece this factor is noticeable, even more when you are carving aluminium rather than wood, thats why the milling machines are heavy, especially CNC centers. Another thing to check is the connections between the motors and the ballscrews.... check all the mechanic parts first, as per very small pieces and high acceleration you are going to join another world with a high inversion rate, is called "jerk"
    A router is a router, and as much as you like it, is shaking and flexible under high torque.....
    I would suggest you to lower the acceleration to 300/500mm Min and look if the problem is persistent before retuning all the motors and blame them or the controller.
    Regards
  12. The Following User Says Thank You to Merlin201314 For This Useful Post:
  1. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  2. FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
    By lateAtNight in forum Items For Sale
    Last Post: 24-06-2014, 03:41 PM
  3. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
