    I did not follow the advise to plan before buying!!! I have a set of ball screws & nuts 1605's. 300mm, 1000mm & 1300mm long. I bought these off aliexpress, when on offer. With how things have panned out they are surplus to requirements, still in the packaging, I only opened them to check they were as they should be.
    i am after £80 for them shipped to your door. I paid slightly more but got stung for customs as well.
    i also have a number of other bits, off a machine I am refurbishing, with guidance from Dean. I am basically replacing the controllers and motor drivers, I have 3 gecko G201x drivers and some cnc4you controllers if anyone's interested to.
    hi there,
    now dont get me wrong but i will be looking for some ballscrews but...
    i am new to all this
    so.........
    whats the overall pitch length on the screws, ie the travel and also the nut dimensions
    im so new i dont yet understand why a lot of them are machined at one end............
    thanks in advance
    I think the answer was here
    It means the screws are 16mm with 5mm pitch with the lengths as stated. When they say machined at one end it means that they have been machine to accept the bearing (usually an AC type bearing) and the bit to put the drive pulley or coupling on.The other end of the screw is generally machined to accept a standard bearing .
    im after cheap controller from cnc4you if you still have them
    Woodman, are the screws pre-machined ?
    .Me
ID:	19371Click image for larger version.
ID:	19372Yes I still have the boards, see pics attached. Price say - 50% of price new including postage, so £16 for the cnc4you one, and £5 for the mach3 interface board. PM me details if interested.
    The ballscrews are machined for fixed free configuration, ie for bk12 and bf12.
  1. 1202 ball screws with flangless nuts?
    By dazza in forum Lead Screws, Nuts & Supports
    Last Post: 03-12-2014, 12:42 PM
  2. Replacing Chinese screws/nuts with British bought gear.
    By Wal in forum Lead Screws, Nuts & Supports
    Last Post: 15-11-2014, 11:30 PM
  3. have you put ball screws on an X2plus?
    By bmbaz in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2014, 06:56 PM
  4. buying ball screws
    By bmbaz in forum Marketplace Discussion
    Last Post: 10-05-2014, 03:57 PM
  5. Plastic ball nuts - any thoughts ?
    By EddyCurrent in forum Lead Screws, Nuts & Supports
    Last Post: 26-03-2014, 11:30 PM
