    Hi Guys
    Have been meaning to have a look @ a rechargable device that stopped working a while ago.
    Stripped it and the batteries are AA but the connection is made via a small pin on either end that locates in a v shaped connector.
    Has anyone come across this type of Battery and do you know the type or part No i can Google.
    Regards
    Mike
    Hi Mike,
    A picture might be useful. Any markings on the batteries,are they NiCd or NiMh or lithium ?
    RS have tag ended AA's but not pin ended.
    Cheers,
    Rob
    Hi Rob
    Thanks for your reply, i boxed the device back up to try it on the charger again after cleaning the contacts.
    got a reading of about 1.3 volts on both cells and when i pressed one of the buttons a LED flickered into life then faded, new item is about 50 squids so will have a look at a Chinese knock off.
    Thanks again.
    Mike
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    A quick google threw this up - https://cellpacksolutions.co.uk/prod...mmon-sizes/aa/
    Try the Termination selection menu down the right hand side to see if any look similar.
    Thanks for that m-c
    the pins are about 2.5mm dia and about 4mm long one end and 6mm the other.
    more chance of finding Hen's teeth.
    Regards
    Mike
    If you're otherwise going to bin the item, just get some tag ended batteries and solder them onto the contacts. Even use a bit wire if needed.
    Other option would be to make up some suitable adapters/pins from something solderable, and get some of the axial pinned batteries from that link and solder/trim them to the adapters.
  7. The Following User Says Thank You to m_c For This Useful Post:
  1. 1 voltage meter for both solar panel and battery
    By deannos in forum General Discussion
    Last Post: 01-08-2014, 07:41 PM
  2. Very simple for special tool expert … heeeelp!
    By hoezap in forum Tool & Tooling Technology
    Last Post: 14-07-2012, 08:57 AM
  3. WANTED: Anyone have one of the ebay special 50V 500W Minebea PSU's still?
    By jamezwarner in forum Items Wanted
    Last Post: 28-05-2012, 11:14 AM
  4. Special offer on Shark Fx v7
    By m.marino in forum General Discussion
    Last Post: 05-01-2012, 05:17 PM
