    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I've soldered the cable following this exact drawing: http://www.denfordata.com/bb/download/file.php?id=1263 - the same that you've highlighted, Peter. What do you mean by 3 wires?
    A serial link will work with just 3 wires (but not all links) they are TX,RX & common: pins would be 2,3,7 in a D25 setup .
    Now you need to say what com port is on your pc as there are 25 pin and 9 pin (also there can be a parallel port that has 25 pins) So are you sure you are not plugging into the PP?
    Have you done a continuity check between the pins on the plugs to see if you have any shorts etc.
    I don't know your Denstep card a pic. of the system might help.
    As Clive has said serial can work with just the 3 wires BUT it all depends on what is sending the signals and what is receiving them as to what connections are needed.
    Does your Denford machine have a 25 pin input or as you alluded to a 9 pin to 9 pin lead has it a 9 pin input.
    As you are finding out the whole rs232 saga is one of trial and error, in the past when I was involved with such things I collected a selection of leads and adaptors just so that you could get the 2 parts to communicate with each other - then you could get a lead or make one.
    I was never sure whether the manufacturer tried to keep things secret or they just didn't know themselves!
    These days things are much easier now that the rs232 has gone (mostly) by the way.
    Just as a thought have you checked the controller PC that it has the right port enabled as some require them to be enabled in the bios(if memory serves)
    Peter
    How do you check that the PC has the right port enabled? It only has three ports; 9 pin male (connecting to Denford), 9 pin female (connecting to screen) and parallel port (not used). I need to make sure the PC is right for the machine!
    Thanks for your help but I think I'll just resale the machine and computer without the cable. My knowledge of electronics is too limited.
    Stuart
    Stuart I don't think you have a 9 pin port to your monitor that is most likely VGA 15 pins.
    I am not saying connect different to the drawing. I was trying to point out that besides the pins 2,3,7 there are other pins for handshaking etc.
    The pc would normally have the port enable by default. But you could check in the bios to be sure.
    Are you sure you are not getting mixed up with the pin numbering as you have a female on the pc
    Did you look at this link by Peter http://www.denfordata.com/bb/viewtop...BI01812A#p8630 But I see you have posted there.
    Have a read of this - shows some of the headaches with RS232
    http://retired.beyondlogic.org/serial/serial.htm#4
    Also shows the internal links required for null modem!
    Peter
    Denford will sell you one, call them
  1. a few link might be helpfull foe new diy machines
    By feetsy in forum Gantry/Router Machines & Building
    Last Post: 01-05-2015, 04:33 PM
  2. New to this game and need link to Chai at lineramotionbearings Ebay page
    By worksengineer in forum Marketplace Discussion
    Last Post: 30-06-2014, 06:37 PM
  3. CNC controller with serial (RS232) communication
    By rnr107 in forum Motor Drivers & Controllers
    Last Post: 28-02-2012, 09:49 PM
  4. Plastic link chain cable carrier.
    By adscnc in forum Gantry/Router Machines & Building
    Last Post: 11-12-2009, 06:35 PM
  5. Missing link found? 47 million-year-old primate - Darwiniu
    By Lee Roberts in forum General Discussion
    Last Post: 20-05-2009, 06:17 PM
