Thread: Advice on converting my VMC
06-10-2016 #19
Yes works exactly like this.
M6 in G-code tells mach to turn on output #? and wait until input #? goes high or low then carry on with Job. The PLC is programmed to do the tool change when it sees Mach's output on it's input. Then when finished turn on it's Output which mach see's on it's Input. The shows goes on.!
Common for ATC's to use PLC for tool change. That said for ATC's which don't require massive amounts of I/O Macro works just as well. The Cslabs as plenty of I/O and don't think this ATC needs lots of I/O so don't see the point my self.
I think the guy who used the PLC will have done so because he didn't have enough I/O. This is one reason why the Cslabs are so good for retrofits because they come with plenty of I/O and can easily be increased without costing the earth.Last edited by JAZZCNC; 06-10-2016 at 09:45 PM.
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Advice Needed, Converting a Boxford VMC 190
By Marv2097 in forum Boxford Vertical MillsReplies: 17Last Post: 19-12-2016, 05:53 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM
