Thread: Advice on converting my VMC
27-09-2016 #1Boyan I have a house in Spain for the last 15 years and I know that the electric supply is crap (but is getting better very slowly) that means the electric can go off on a regular basis which is very bad for hard drives as you know. This just does not happen in the UK. I have had hard drives lasting more than 15 years.I spend a couple of years here in Spain repairing PCs as a side job. Number one fault at least 50% in cases=faulty hard drive
cheap PC for garage =old pc= possible near future hard drive fault.
You missed the pun about the Russians! I do think that your comments about the Chinese etc. are really not acceptable to me and probably others as well.
I was suggesting you put links up for the more expensive ones with good support.Cause they are more expensive than the boards could be found
Now this is the Op's thread and we should not hijack it . My opinion is different to your's so I will leave it as is.Last edited by Clive S; 27-09-2016 at 10:51 AM.
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Advice Needed, Converting a Boxford VMC 190
By Marv2097 in forum Boxford Vertical MillsReplies: 17Last Post: 19-12-2016, 05:53 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM
