Thread: Advice on converting my VMC
04-10-2016 #2
Thanx guys for your information :-)
Like i said, i`m a newbie on this, and i spent most of my time lately in the evening/night reading myself up on Bob`s, Motion Controllers, drivers and steppers.
Last night i had to tuck myself in bed at 2 o`clock in the night, just before my mains circuit in my head blew :-)
Ok, so i have concluded with the CSMIO/IP-S as my motion controller as it seams to be compatible witch Mach software, and in use by many.
Besides thats the price i have to pay to simplify installation of the original ATC with its sensors and pneumatic valve system.
Listening to you guys, i have choosen to step the voltage up to 72V using the KL-7220 Unregulated Linear 1440W/72VDC/20A Toroidal PSU from Automation Technologies.
(I thought noice was a real issue with CNC machines, and keeping it down to 24Vdc industry standard was considered the way to go?)
Just have to keep noise issues in mind, and shield as much as possible. The cabinet has seperate compartments already, and should help a bit.
As for steppers and drivers, i have decided to use the KL34H280-45-4A NEMA34 640 oz-in 4.5A Stepper Motor, and KL-8056D Digital 2 bit DSP Based - Bipolar Stepper Motor Driver.
Any last minute advice or comments ?
Links.
KL34H280-45-4A : http://www.automationtechnologiesinc...otor-640-oz-in.
KL-5056D : http://www.automationtechnologiesinc...nk-is-included
KL-7220 : http://www.automationtechnologiesinc...0vac-or-230vac
CSMIO/IP-S: http://www.cs-lab.eu/en/produkt-2,2-...onnectors.html
Will try my best to document the conversion and perhaps help others that might be in a somewhat similar situation.Last edited by Proteus; 04-10-2016 at 11:47 AM.
04-10-2016 #3The 24V you are reading about is generally for the estop, inputs etc. not for driving the motors. A lot of bobs only work with 5V inputs so it is possible to get spikes (noise) that can trigger an input this generally does not happen when using 24V.(I thought noice was a real issue with CNC machines, and keeping it down to 24Vdc industry standard was considered the way to go?)..Clive
04-10-2016 #4
My advise is don't buy any of that lot from Automation or Kelling cnc as it used to be known.? You'll be paying far more than need to for only average components. (the fact your looking here makes me suspect you've been around our american cousins on cnczone.?)
First the Drives are just rebadged cheap chinese drives and for less money you could by Leadshine drives that are much better and higher voltage. Like AM882 or EM806.
Also take note you keep showing links for drives that are only capable of 50Vdc max. Even the higher 8056D can only handle 70Vdc Max which means allowing for safety factor you'll need to run them around 60Vdc.
The PSU is fine (except it's too large for those drives) but you could easily build the same thing for half the price. Very easy to build as many on here will tell you.
The motors are ok but do you really need 34's.? What size machine is it.?
Regards the 24Vdc and noise(EMF) then this is mostly for control circuits. The CSlabs only works with 24Vdc so you'll still need 24 supply but only small 2-3A switch mode affair for e-stop, limits etc.
The higher voltage lowers the chance of EMF affecting signal lines and when used with correct shielded cable you'll have very stable system. Coupled with high quality of Cslabs controller you'll be very noise immune.Last edited by JAZZCNC; 04-10-2016 at 05:26 PM.
05-10-2016 #5
Thanx Jazzcnc for advice and comments :-)
And yes, i am a member of CncZone as well. There are some Norwegian members there, and i like to hear all those different opinions ;-)
Ok, it seems i was a bit offline when i replyed to the thread. Mentioned KL-8056D but provided a link to KL-5056D.
I did send Automation a mail last night asking why the they list KL-8056D for "up to +7Vdc", when the datasheet say +20 to +80Vdc.
If what i have read around is correct, the KL-8056D is a re-badged Leadshine DM870. And Leadshine says +20 to +72Vdc in their datasheet(found that out today)
Dissapointing and very confusing, but this fact eliminates the KL-8056D.
Tried to find a price for the AM882 and EM806 and they don`t come cheap. Found some new AM882 at a reasonable price though and may decide on them.
What about the MA860H? Does anybody have any experience with the MA860H ?
Leadshine datasheet says input voltage of max 80Vac or +110Vdc, 7,2A. Price 58,88 on steppers-online.
I do have a lot of experience with PSU(both switched and lineary) Jazzcnc, and having a larger than necessary PSU only ensure less voltage drop at high loads.
Besides i want to have enough for the 4th axis.(might even put in the 5th axis in time if i get if i get excessively geeky
And beleive me Jazzcnc, i have searched the entire Norweginan marked for parts to build it my self. That will cost me twice as much.
The reason for me choosing Nema34 motors is only because it has Nema34 motors originally. (Lacy me, don`t have to manufacture new mounting brackets)
Final thoughts with renewed thanx to good advice from Jazzcnc:
Stepper drivers.
AM882 or MA860H(Havent decided yet.
http://www.leadshine.com/productdeta...AM&model=AM882
http://www.leadshine.com/productdeta...M&model=MA860H
Stepper motors.
KL34H280-45-4A or 34HS38-3008S(Havent decided yet, and yes).
http://www.omc-stepperonline.com/nem...008s-p-32.html
Motion COntroller and PSU will still be CSMIO/IP-S and KL-7220.
I do beleive this should summarize a good setup, unless there is something i don`t see(again)
And again, thanx for advice and comments gents
06-10-2016 #6
Ok first lets drop the Jazzcnc just call me Dean others do and I don't mind.
Nothing wrong with the Zone just little unwieldy and state biased.!
Exactly why shouldn't rush onto buying before doing the home work. Very easy to buy wrong stuff.
These are Analog drives not digital. Analog is Old tech best avoided and don't compare to good digital drive.
If you want AC Digital drives then there's model AM882-H
You can't have voltage higher than than drives Max else you'll blow the drives up. infact you don't want the voltage near the drives Max you want it approx 10% less.
Now Current is different matter and I was talking about voltage.!
I'm very surprised you can't find toridal Transformer and 3 x capacitors cheaper than $200.!!
No better reason required.!
.Last edited by JAZZCNC; 06-10-2016 at 06:24 PM.
06-10-2016 #7
Will be setting up a multichannel(24) National Instruments DAQ/ADC system analyzing the signals when i run the tool change.
That should give me a "time map" for all signals initiated with mS or even uS timing, and compare it to the schematics of the system.
Which again would give me insight to compare it to all the options with the CSMIO/IP-S unit.
Talked to Rob(The Engine Guy) at the Zone who bought a VMC300, and the guy owning it before him used a Koyo Direct Logic PLC to program and run the ATC.
That makes me wonder if i shouldn`t be able to do the same with the CSMIO/IP-S. And even with Mach compatibility.
Will start to tear down all the old electronics after taht, prepping the VMC for new shiny parts. Can`t wait :-)Last edited by Proteus; 06-10-2016 at 09:13 PM.
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Advice Needed, Converting a Boxford VMC 190
By Marv2097 in forum Boxford Vertical MillsReplies: 17Last Post: 19-12-2016, 05:53 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM
