30-06-2017 #51
Better late than never
but guitars are something I'm very interested in so I will start to follow this thread once I've caught up on the reading.
P.S Where are the project files ? will they open in Rhino ?
Edit: I think I'm correct in saying that the project files are accessed through Fusion360, in which case I won't be getting to them.Last edited by EddyCurrent; 30-06-2017 at 07:01 PM.
30-06-2017 #52
30-06-2017 #53
When you sanded the fretboard black dots it looks like there was no contamination of the maple grain. I once used ebony dots and upon sanding, it went right into the lighter wood's grain.
I liked the idea of using a lathe to drill the truss rod hole in the heel, I guess the neck was horizontal because you were using a 2 way truss rod rather than a bowed threaded rod.
Here's a pickup ring I made recently for a humbucker, toolpaths made in CamBam
30-06-2017 #54
My CNC Projects: https://www.youtube.com/imadethisoncnc
30-06-2017 #55
Yes it was a double action rod and horizontal - hence all the "hiding" I had to do to make it look like the original single action bow type with cross head adjuster.
The maple grain was fine after sanding, normally I would clean the fret board before spraying, but this particular guitar is supposed to look like a 62 vintage, so I'm currently testing ways on offcuts of "dirtying" the wood up that also allows nitro lacquer to still adhere (which will then sadly be "worn" back again somewhat to replicate wear).
Nice pickup ring BTW.My CNC Projects: https://www.youtube.com/imadethisoncnc
01-07-2017 #56
05-09-2017 #57
Been on a bit of a break from the guitar project, but lacquer has finally started to be laid down (not without some trouble of my own making):
05-09-2017 #58
Nice burst!
05-09-2017 #59My CNC Projects: https://www.youtube.com/imadethisoncnc
06-09-2017 #60
FOR SALE: CNC project
By amxen in forum Items For SaleReplies: 1Last Post: 20-12-2015, 09:19 PM -
NEW MEMBER: Hello My CNC UK community
By Xavi in forum New Member IntroductionsReplies: 2Last Post: 30-11-2015, 09:01 PM -
Community Shed
By Musht in forum General DiscussionReplies: 12Last Post: 06-10-2013, 12:15 PM -
Central South Community
By Leadhead in forum General DiscussionReplies: 1Last Post: 26-09-2011, 02:50 AM
