    I perfectly understand what you are saying, after 2 weeks spent trying to figure things out and reading manuals. Its an absolute mess. I even have tried to make an Excel file so i could compare. They have absolutely no idea how to sell a product to an European or a Westerner in general.
    You would not believe the insane conversations i had last 2 weeks with different Chinese companies.
    What is your specific need that you find that you need the 218 versus 980 controller?
    Lives in East Lothian, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Komatias, I've not got any plans to be down that area, but if I do happen to be, I'll give you a shout.
    Boyan, the GSK990 (their 980 now appears to be a bus link unit only) is just a pretty basic control panel, whereas their 218MC-H or V control panel comes with E-stop,FRO,SSO,Cycle Start/Stop knobs/buttons. The only option listed for the 990, is an additional panel, which is just a precut frame for adding your own controls.
    The reason I'm looking at the Chinese controller option, is I want a ready made control panel, and don't want to be faffing around making one. If I wanted to do that, I've got a KFlop+Kanalog+KStep sat in a cupboard, or a pair of Mesa boards lying around that would work well for this machine, but both of those involve trying to mount a PC in the machine.
    I have just bought one of these:
    http://www.mini-itx.com/store/?c=34#JNF9C-2600
    with a SSD it will also run off 12V It is being mount on the control box door inside. Using a mesa 5i25/7i76 combo
    I'm well aware of mini-ITX boards, but you still need to make a control panel.
    Ideally I'd just like to modify/make a housing, wire the controller in, bolt it in place, configure it, and be good to go.
    The big thing is cost/time.
    A good metal industrial panel mount keyboard with track pad/ball is around £200, a suitable resistive touchscreen monitor is another £200, then you have the cost of separate switches, which will probably be at least £50 for good quality ones, and say another £50 for assorted wiring/connectors to connect that lot up. That's £500 before you even consider the controller or PC, which means you can quite easily spent £1000 on the hardware. Then you still need the time to design it all, build it, and wire it up.
    Admittedly, that's buying stuff new, and building a good industrial quality controller, which is overkill for most hobby users, but when you need the machine to make money, you have to consider the whole picture.
  1. Comparing motion controllers...
    By JW1977 in forum Control Hardware & Systems
    Last Post: 17-02-2016, 02:36 PM
  2. Wiring Steppers to controllers
    By liamo1991 in forum Motor Drivers & Controllers
    Last Post: 05-09-2013, 01:58 AM
  3. PCI Motion Controllers
    By IanS1 in forum Motor Drivers & Controllers
    Last Post: 16-05-2013, 12:13 AM
  4. Difference between controllers and Cad/Cam programming???
    By 0625272 in forum Computer Software
    Last Post: 23-06-2011, 08:40 PM
  5. Programmable logic controllers
    By cncezee in forum Motor Drivers & Controllers
    Last Post: 15-11-2010, 08:44 PM
