Thread: Large cnc routing cutter needed
Buy a couple of this one 1/2" shaft and 2" diameter. Its dirt cheap for what it is. You could easily modify the corners yourself. Or let somebody grind it for you. basically you have to round them, take same amount from the back support.
And sharpening and resharpening could not be easier on this bit using 600 and 1000 grit diamond plate.
There are cheap plates, a bit more expensive plates and there are better expensive plates. Which both work. Here is the how to video
Anyway, the keyword is "bottom cleaning bit" . That's how the Chinese call them.
05-10-2016 #2
thanks they look perfect just a pity they will take so long to arrive. Ill buy a few.
05-10-2016 #3
there are in UK http://www.ebay.co.uk/itm/BOTTOM-CLE...0AAOSwQPlV9vZl
05-10-2016 #4
Wealden have a cutter with a round edge - they don't state what the radius is - ring them up
http://www.wealdentool.com/acatalog/..._Wing_250.html
Peter
05-10-2016 #5
This any use ? http://www.ebay.co.uk/itm/Trend-Radi...item3f5b014dda
05-10-2016 #6
RFQ: LARGE CNC job - need help
By ChristoT in forum Projects, Jobs & RequestsReplies: 0Last Post: 18-10-2014, 01:48 AM -
Transporting a large CNC
By gavztheouch in forum General DiscussionReplies: 9Last Post: 02-11-2013, 05:09 PM -
Question on PCB and routing
By Fivetide in forum General ElectronicsReplies: 20Last Post: 12-05-2013, 06:35 PM -
PCB Isolation Routing
By CHudson in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 10-10-2010, 08:34 PM -
BUILD LOG: routing 3d?
By proddy in forum DIY Router Build LogsReplies: 2Last Post: 03-08-2009, 11:20 PM
