Done some editing to the Fusion 360 one to work with my machine. What is it you need?
Here is a link to the functions you can use: https://github.com/AutodeskCAM/Docum...-sm-130829.pdf
and here is a video: https://www.youtube.com/watch?v=imnUJLChlXELast edited by komatias; 14-10-2016 at 08:11 PM.
https://emvioeng.com
15-12-2016 #2
komatias: I would like to thank you for the links above.
I have been trying to make use of the details provided.
Unfortunately I have never done any kind of Java / JavaScript programming before.
I have found a newer postprocessor "mach3mill.cps, dated 12 Aug 2016.
One of the things that I would like to edit the post processor to do, is that I would like the spindle direction and speed to be called at each machine operation, and not only when a tool is changed or a change of speed.
I have attached a copy of the mach3mill post processor, it is using the txt file extension so please rename to cps as needed.
Thanks for your time.
Best Regards.Last edited by Mad Professor; 15-12-2016 at 09:04 PM.
"If first you don't succeed, redefine success"
15-12-2016 #3
Prof,
be careful with that post. It seems to be written with chinese spindles in mind.
So just so I am clear.
Say you have 3 contours you are milling, which are three different lines in the operations tree, but use the same tool:
You want the M3 and S**** codes to be put at the start of each one even though a T** and a M6 are not called.
Will have a look where we can add this.https://emvioeng.com
16-12-2016 #4
komatias: Thanks for your reply.
That is exactly what I would like to happen, please see example codes below.
Current post processor output.
Required post processor output.Code:G90 G94 G91.1 G40 G49 G17 G21 G28 G91 Z0. G90 (2D ADAPTIVE1) M5 M9 T1 M6 S10400 M3 G54 M9 !!! BLOCKS SKIPPED HERE !!! !!! PROGRAM IS ONLY FOR REVIEW !!! (2D CONTOUR1) M9 !!! BLOCKS SKIPPED HERE !!! !!! PROGRAM IS ONLY FOR REVIEW !!! (2D CONTOUR2) M9 !!! BLOCKS SKIPPED HERE !!! !!! PROGRAM IS ONLY FOR REVIEW !!! M9 G28 G91 Z0. G90 G53 G0 X0. Y0. M30
Thanks again.Code:G90 G94 G91.1 G40 G49 G17 G21 G28 G91 Z0. G90 (2D ADAPTIVE1) M5 M9 T1 M6 S10400 M3 G54 M9 !!! BLOCKS SKIPPED HERE !!! !!! PROGRAM IS ONLY FOR REVIEW !!! (2D CONTOUR1) M9 S10400 M3 !!! BLOCKS SKIPPED HERE !!! !!! PROGRAM IS ONLY FOR REVIEW !!! (2D CONTOUR2) M9 S10400 M3 !!! BLOCKS SKIPPED HERE !!! !!! PROGRAM IS ONLY FOR REVIEW !!! M9 G28 G91 Z0. G90 G53 G0 X0. Y0. M30
Best Regards."If first you don't succeed, redefine success"
16-12-2016 #5
Prof,
I will have a look in the next few days and report back. May have to look into the functions that are called per operation which I played with them for a while so will need to investigate.
The other option is to submit a question on the Fusion 360 community pages on the autodesk site. they are very helpful.https://emvioeng.com
Post Processor for Heidenhain tnc 145???
By jackpat in forum CAD & CAM SoftwareReplies: 15Last Post: 04-07-2016, 10:17 PM -
editing files inside solidworks
By reefy86 in forum SolidworksReplies: 7Last Post: 17-02-2016, 12:20 AM -
Help with Post Processor
By superpot in forum CAD & CAM SoftwareReplies: 0Last Post: 20-11-2013, 11:23 AM -
Vectric Post Processor
By p1lts in forum General DiscussionReplies: 2Last Post: 08-10-2011, 08:02 PM -
Post processor Sei
By 2006Nobull in forum Machine DiscussionReplies: 12Last Post: 04-08-2011, 12:58 PM
