16-10-2016 #1
I'm thinking how best to implement these.
I could use either encoders, or potentiometers.
My current thought is encoders, as overrides could then be reset in software, but when would you want to reset them?
I'd have the ability to program things to reset whenever I wanted, but when would that be?
When you disable the override?
When a new feedrate is called?
Then do you reset them when re-enabling the overrides?
At the moment, I rely on onscreen overrides which you have to manually reset to 100%, however I can think of situations where all the above could be handy, so I'm struggling to make decision.
Regarding the encoder v. pot, I'm thinking encoder, as there could potentially be several meters of wiring needed between the control panel and cabinet, so a high value pot would be susceptible to noise, which could cause unwanted fluctuations (off course, a small capacitor at the controller analogue input would help smooth out any noise).
So I'm interested to hear other peoples thoughts.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
What feed and speed for Oak
By Clive S in forum Woodwork DiscussionReplies: 1Last Post: 13-02-2015, 11:32 AM -
Feed and speed equation
By Bush Flyer in forum Spindles & Drive MotorsReplies: 7Last Post: 18-03-2014, 01:32 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Router bit recommendation, spindle speed and feed rate?
By FlightCaseCo in forum Spindles & Drive MotorsReplies: 13Last Post: 03-04-2012, 12:53 PM
