Thread: Denford Mirac conversion help
08-11-2016 #19
Sounds like you've got one of Denford's own DM turrets.
Is it like the diagram in this thread? - http://denfordata.com/bb/viewtopic.php?f=40&t=157
Having had a quick look at the wiring diagram and the description in that thread, it seems to be a case of rotate turret clockwise until position matches, then immediately reverse the turret, at which point it should lock.
Depending on how fast the turret spins, you may have a problem, as with the 10Hz macro refresh rate, you have a 100-200ms reaction delay depending on timings. However I can't find any info on the timings required, so it'll have to be a case of try it and see.
I've not done any Mach3 macro programming for a long time, so I'm hoping somebody will convert the following to the required Mach3 code-
You'll also want to add safety time outs at various places, as if the turret fails to lock, you don't want it to sit spinning endlessly, until you manually stop it running.Code:While (TurretPosition <> CommandedPosition) ActivateTurretCW EndWhile DeActivateTurretCW (a slight time delay may be needed here?) ActivateTurretCCW While (TurretNotLocked) (Do Nothing) EndWhile DeActivateTurretCCW
One option you do have, due to the turret using a VFD, is you could slow down the rotation to give Mach more time to respond.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Whats it worth, Denford Mirac CNC Lathe
By Dean jeffery in forum Marketplace DiscussionReplies: 4Last Post: 03-07-2014, 01:38 PM -
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
FOR SALE: Denford Mirac CNC Lathe with Auto Tool Changer For Sale
By CHudson in forum Items For SaleReplies: 3Last Post: 19-02-2011, 12:11 AM -
RFQ: Looking for somone to finish conversion Denford Mirac with Mach3
By CHudson in forum Projects, Jobs & RequestsReplies: 0Last Post: 14-10-2010, 08:20 PM -
Denford Mirac Electronics Refurbishment
By CHudson in forum Computer SoftwareReplies: 11Last Post: 17-06-2010, 08:30 PM
