  1. #26
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Basically each time you activate a signal, you need to also set a timer, so if the required input signal doesn't happen within the timer, things fault out (use a DoOemButton(xxxx) where xxxx is the code for E-stop), however I've totally forgotten how you do that in Mach3 Macros :-/
    A quick search on the Mach forum has thrown up this thread - http://www.machsupport.com/forum/ind....html#msg86334
    Look at the "timeout" variable and how it is updated/monitored.
    That macro also has the required OEM button numbers.
    You should also add a check before the end of the macro which checks that the correct tool position has been achieved.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. Whats it worth, Denford Mirac CNC Lathe
    By Dean jeffery in forum Marketplace Discussion
    Last Post: 03-07-2014, 01:38 PM
  2. Replies: 19
    Last Post: 21-08-2013, 11:20 PM
  3. FOR SALE: Denford Mirac CNC Lathe with Auto Tool Changer For Sale
    By CHudson in forum Items For Sale
    Last Post: 19-02-2011, 12:11 AM
  4. RFQ: Looking for somone to finish conversion Denford Mirac with Mach3
    By CHudson in forum Projects, Jobs & Requests
    Last Post: 14-10-2010, 08:20 PM
  5. Denford Mirac Electronics Refurbishment
    By CHudson in forum Computer Software
    Last Post: 17-06-2010, 08:30 PM
