    I had a quick look tonight at runout, from what i can measure there is no runout in the spindle socket (ER20) so thats ok, but the collet - thats another story!
    I put the 2mm tool in with about 20mm shank protruding, near the collet there was 0.1mm runout - pretty bad, further down the shank near the flutes it measured 0.1mm again. I marked the retaining nut and spindle at the point with the largest reading and rotated the collet in the socket 180deg.
    The nut was tightened back to the same point and the measurements taken again. This time the high point had moved with the collet but was the same.
    Sounds like a totally junk collet :)
    Will find some decent ones i think.
    This is the cut spec leaflet, the single-flute E5E47 range.
Name:	YG-1 Alu-Power Carbide End Mills.pdf
    The material is firmly clamped, no movement, either 3mm or 5mm thick.
    Did you buy standard or close tolerance collets?
    Standard - all my stuff is pretty much "standard" ;)
    Yesterday i found one of the right size with 0.03mm runout so i'm using that one for now.
  1. How-To: Feed Rate Calculation
    By Lee Roberts in forum Machine Discussion
    Last Post: 25-03-2020, 04:09 PM
  2. Replies: 0
    Last Post: 14-07-2015, 09:45 AM
  3. Any builders in the Tyne & Wear area?
    Last Post: 19-10-2014, 07:35 PM
  4. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  5. Any guys from Tyne & Wear?
    By D-man in forum General Electronics
    Last Post: 11-10-2009, 11:44 AM
