I have no issue with the wiring or electrical side of this so savvy in that respect(to a point lol), I just wondered if it was as simple as replacing the controller side and rewiring up to it or have I missed something vital?
As all the other parts motors, psu, etc.. are still there
24-10-2016 #2
The hard bit is isolating the step and direction signals on the bpard for the inbuilt drivers.
If you can do this then yes it is easy.John S -
24-10-2016 #3
Forgive my lack of correct wording on this, but are you referring to the 2 wire pairs on the stepper motors or do you mean wiring on the controller board that I pick up?
24-10-2016 #4
On the breakout board for a 3 axis machine you will have 6 outputs X, Y, and Z, step and direction.
You will need to find out where these 6 wires need to go on the internal Roland board so that the board can power the steppers.
Failing that you will have to throw the Roland board away and fit three new stepper drivers that you have a wiring diagram for. Then wire the logic side to the breakout board and the output side to the existing steppers.
In the long run this may be easier as you then have known and replaceable components instead of a very old Roland board that could crap out at any moment.
Chances are the Roland board is either full step or half step at best. New drivers will give you micro-stepping to get a smoother drive.Last edited by John S; 24-10-2016 at 06:47 PM.
John S -
24-10-2016 #5
So in theory, if I wired directly from the steppers to say a grbl board that would be all it needed as that has the stepper drivers and also the grbl firmware on the arduino, then just control the spindle with a relay or similar?
24-10-2016 #6
No idea I'm not into garbled boards and arduino's
John S -
24-10-2016 #7
Fair enough lol, so if I went for a mach3 board with stepper drivers and then removed the standard control board and wired straight to the mach board which I'm assuming is the same principle?
WANTED: Roland MDX-40 or 40A or SRM-20
By o_drew in forum Items WantedReplies: 2Last Post: 10-02-2018, 10:22 PM -
SOLD: Roland MDX-40 £2,000
By m_christopher in forum Items For SaleReplies: 0Last Post: 22-05-2015, 11:38 AM -
FOR SALE: Roland engravers
By Bartell in forum Items For SaleReplies: 3Last Post: 11-12-2014, 11:09 AM -
Roland camm 2 pnc 2300 spindle upgrade help
By iampete in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-09-2014, 03:17 PM -
eBay: Roland camm 3 cnc milling machine
By Lee Roberts in forum Items On eBay UKReplies: 0Last Post: 09-01-2014, 10:41 AM
