Page 2 of 2 FirstFirst 12
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Daveo View Post
    ok, so can any point me to a few links so i can get an idea of what i want.as i said i would like it around 1200mm x 600mm
    daveo
    Have you done any research on the forum and looked at some of the very capable machines if you are not careful you will waste a lot of money.
    It shows you have not done much as you are looking at 25mm ball screws with linear supported rails.
    for a decent machine for the size you are looking at you will need 1610 on X and Y and 1605 on Z also the square rails have come down a lot in price are are far better.
    First start a build log with a new post to keep all the questions in one place and then design something in cad there is no problem copying other people designs and then you will have a much better idea.
    The golden rule is don't buy anything until you have a design sorted then the wise ones on here will put you right.
    Good luck with the build .
    hi
    yes you are correct, still trying to find out what i want, i have looked but cant find any builds like i want and was hoping for a few suggestion and then start reading
    so the 25mm ball screws i was looking at are to big?
    thanks daveo
    Believe it or not (and you probably won't until you do the sums) an oversized ballscrew will be a bigger limitation on performance than, say, the weight of the gantry. Especially a 5mm pitch as it has to spin faster than, say, a 10mm pitch, for a given speed. When the gantry accelerates from rest, you have to spin up the ballscrew and the rotational inertia of the ballscrew will be a major factor slowing it down. Ditto fitting a too-big motor - a combination of inertia and other electrical factors will reduce performance. This is why it's important to take guidance from the community here - use their experience rather than paying for your own!
    ok thats good info,thanks
    so i am looking to build a 1400mm x 600mm
    ball screw 1610 on X and Y 10mm pitch and 1605 on Z 10mm pitch ( whats the best motors for theses)
    any suggestions on the aluminium extrusion
    thanks daveo
  5. #15
    Dave whilst we'll all gladly point you in right direction with what's required for componets etc you are still the one who's got to build this machine so if don't do the research and come up with design and fully understand it then 90% chance your going to fail or at very least waste lot of money.
    For instance You say 1400mm but haven't got clue what's required to have machine that length and not run into problems which can and would come with it if not done correctly.
    There is no short cut to doing this correctly so if you Fail to prepare by doing the research then prepare to Fail.
    Don't get me wrong I'm not trying to put you off, far from it. But I am personally deliberatley with holding information from you because I know it wouldn't help you from lots of experience helping builders who have Failed because they didn't learn the knowledge and did rush into buying without clue whats required and why.!
    Strongly urge you to do the research and learn what's required and involved in building machine the size your asking. When you have done this it will become clear why the questions you are asking now are premature and potentialy dangerous to your wallet.
    Do what Clive says start build thread and ask questions about anything you don't understand. By this I don't mean ask about suppliers this comes later and by which time you'll know exactly what you need.
    First You need to know how to make the machine tick and why what you choose makes it ticks this way.!
    Do this and I'll gladly part with my knowledge but won't help anyone waste money( It would Kill yorkshire Man to see wasted cash.!!) which you surely will if carry on without doing the leg work.!
  6. #16
    hi thanks,
    i understand what you are saying, where can i find completed projects so i can read through the build
    daveo
  7. #17
    hi thanks,
    daveo
    Select machines tab and choose the option from there.
  8. #18
    hi thanks,
    daveo
    Hi Daveo
    Just adding my words to what Jazz and Clive S have advised PLEASE take their advice. These guys saved me from making expensive mistakes and even then I still made some! You ask about completed projects - there are many under the build logs - here's mine here well nearly completed! Take time to study the builds, evaluate their strengths and weaknesses. Do your design and get it peer reviewed on this forum. Another pair of eyes from these experienced builders makes all the difference.
    My router has a 1100mm, 700mm and 300mm ballscrews and may well be suitable for the types of projects you are suggesting. I made the mistake of buying 1605 ballscrews instead of 1610 - I did what you want to do - spending money too quickly without thoroughly working out what I wanted to do. For the materials you want to cut 1610 ballscrews on the x an.d y axes with a 1605 on the Z will do just fine.
    Anyway good luck with your design and build
    Regards
    Mike
  1. List of CAD/CAM Software
    By Mad Professor in forum CAD & CAM Software
    Last Post: 1 Week Ago, 07:42 PM
  2. Replies: 4
    Last Post: 26-04-2013, 08:37 AM
  3. CNC machinist: Most hated job list
    By Robin Hewitt in forum General Discussion
    Last Post: 27-08-2011, 01:40 PM
  4. BobCad 80% off list
    By Robin Hewitt in forum BobCAD-CAM
    Last Post: 06-08-2009, 04:25 PM
