Thread: Kinco 2M2280N
	30-10-2016 #1
Long shot this one but does anyone have a pcb schematic for a Kinco 2m2280N stepper driver?
	30-10-2016 #2
	30-10-2016 #3
Unfortunately Ive now got one dead one as well. Still in the process of replacing the eding controller with the cslabs one, haven't really had time to get stuck into it, and powered the drivers up to test the limits and home switches and estop. Reset the estop and the driver went bang. Oddly enough Ive had it stripped down to the board and cant see the flashover mark or a blown component. The driver powers up but comes up with error codes.
I got these one from Gary at Zapp a long time ago but his site shows none in stock. I will need to speak to him tomorrow to sort out a replacement.
Can you think of any problems with using differing types of drivers on the same control system? I can swap things around to have my remaining kinco drivers on the X and Y axis and say have a different one on the z axis.
	30-10-2016 #4
Sorry cant help, what happened to your forum avatar?
Lee, I don't think I ever had one. Never got round to it. I'm sure its on the list somewhere.
	30-10-2016 #6
	30-10-2016 #7
Thanks Dean.
	30-10-2016 #8
	31-10-2016 #9
Bit of an update on this. I have the driver apart on my bench and have found the cooling fan faulty and a shorted IGBT. The fan is easy but waiting for someone to see if they can get me a replacement IGBT.
With the faulty IGBT removed from circuit the existing fault disappears and now says that it cannot find the motor which is correct seeing as its not connected.
I will update again if I can get the correct parts and get it working.
	31-10-2016 #10
Some questions on 2M2280N
By massimomb in forum Motor Drivers & ControllersReplies: 0Last Post: 23-05-2010, 07:56 PM -
2M2280N High Voltage Stepper Driver
By Robin Hewitt in forum Motor Drivers & ControllersReplies: 19Last Post: 14-11-2009, 08:43 AM
