Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    I also ordered the set +some extra, so for 20 euro i will have 3-12mm covered. I was thinking that i will need some new 3-12mm drill bit set that is suitable , should be set where they go 0.1mm each next size, right? Or is there a set made to go with the reamers? So Do you know of something that will not break the bank?
    Lives in Plymouth, United Kingdom. Last Activity: 22 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Yes, I would drill 0.1mm undersize for the smaller sizes, but maybe 0.2mm under for the larger (say, >6mm). Partly that is to make sure that the drill does not cut oversize although with new, good quality, drills that shouldn't be a big problem. If I'm not sure about the accuracy of a drill (typically if I have reground it and the point might be very slightly off-centre) I drill a slightly smaller hole first and then use the "correct" drill. It's more likely to be the correct size that way. Then reamer if needed.
    You can probably tell that I don't do this professionally - the professional buys decent quality tools because time is money
  3. #33
    I was wondering the same thing after my reamers arrived. The lookup tables show 0.1 or 0.2mm undersize is required as per Neales reply but I couldn't find a 'set of reaming drills'. Only standard sets which were in 0.1mm increments. Why isn't there such a thing as a set of reaming drill bits? Other option is to buy them individually from someone like Tracy Tools in the respective sizes for each reamer.
  4. #34
    Not sure that I've ever seen such a thing. I suppose that it makes sense - like sets of tapping and clearance drills? - but the usual dealers just sell the 1-10mmx0.1 type sets. I've bought a few of them over the years; the "special" sizes tend to get replaced as needed and I use the other sizes for general non-critical work. I've used UK Drills as an online supplier and their stuff seems OK but you end up buying 10-off for most sizes...
  5. #35
    OK ....I ordered a set and received two of them...about a week apart...lol.....but not had anything since. Anyone else still waiting for the full complement?
  6. #36
    I'm still waiting for the balance, 2 delivered so far but away from home today so no idea if anything has been delivered today. I'll leave it until Tuesday or Wednesday and then put a claim in to eBay
    John S -
  7. #37
    Chaz's Avatar
    Ive also received two thus far .... waiting for the rest. Odd.
  8. #38
    Quote Originally Posted by camhguh View Post
    The remaining reamers turned up today, so all is good :)
  9. #39
    Mine arrived this morning, all in one package
    John S -
  10. #40
    I'm going for the £11.95 set:
    http://www.ebay.co.uk/itm/New-Chucki...FTJpXNFONNKJHw
    Maybe this seller saves £1 by posting them in one lot...
  1. FOR SALE: Pssst. Compressor - grab a bargain!
    By Wal in forum Items For Sale
    Last Post: 15-03-2014, 12:32 AM
  2. Taps, Dies and Reamers (All kinds and specialty sizes)
    By smartcookie in forum Manufacturer News
    Last Post: 06-06-2012, 03:03 PM
  3. Bargain for someone on eBay
    Last Post: 17-07-2010, 09:48 PM
  4. Is this a bargain?
    Last Post: 25-05-2010, 05:53 PM
  5. Bought myself a lathe.....bargain!!
    By HiltonSteve in forum Milling Machines, Builds & Conversions
    Last Post: 28-12-2009, 05:09 PM
