I also ordered the set +some extra, so for 20 euro i will have 3-12mm covered. I was thinking that i will need some new 3-12mm drill bit set that is suitable , should be set where they go 0.1mm each next size, right? Or is there a set made to go with the reamers? So Do you know of something that will not break the bank?
19-11-2016 #2
Yes, I would drill 0.1mm undersize for the smaller sizes, but maybe 0.2mm under for the larger (say, >6mm). Partly that is to make sure that the drill does not cut oversize although with new, good quality, drills that shouldn't be a big problem. If I'm not sure about the accuracy of a drill (typically if I have reground it and the point might be very slightly off-centre) I drill a slightly smaller hole first and then use the "correct" drill. It's more likely to be the correct size that way. Then reamer if needed.
You can probably tell that I don't do this professionally - the professional buys decent quality tools because time is money
19-11-2016 #3
I was wondering the same thing after my reamers arrived. The lookup tables show 0.1 or 0.2mm undersize is required as per Neales reply but I couldn't find a 'set of reaming drills'. Only standard sets which were in 0.1mm increments. Why isn't there such a thing as a set of reaming drill bits? Other option is to buy them individually from someone like Tracy Tools in the respective sizes for each reamer.
19-11-2016 #4
Not sure that I've ever seen such a thing. I suppose that it makes sense - like sets of tapping and clearance drills? - but the usual dealers just sell the 1-10mmx0.1 type sets. I've bought a few of them over the years; the "special" sizes tend to get replaced as needed and I use the other sizes for general non-critical work. I've used UK Drills as an online supplier and their stuff seems OK but you end up buying 10-off for most sizes...
19-11-2016 #5
OK ....I ordered a set and received two of them...about a week apart...lol.....but not had anything since. Anyone else still waiting for the full complement?
19-11-2016 #6
I'm still waiting for the balance, 2 delivered so far but away from home today so no idea if anything has been delivered today. I'll leave it until Tuesday or Wednesday and then put a claim in to eBay
John S -
20-11-2016 #7
Ive also received two thus far .... waiting for the rest. Odd.
21-11-2016 #8
22-11-2016 #9
Mine arrived this morning, all in one package
John S -
22-11-2016 #10
I'm going for the £11.95 set:
http://www.ebay.co.uk/itm/New-Chucki...FTJpXNFONNKJHw
Maybe this seller saves £1 by posting them in one lot...
FOR SALE: Pssst. Compressor - grab a bargain!
By Wal in forum Items For SaleReplies: 2Last Post: 15-03-2014, 12:32 AM -
Taps, Dies and Reamers (All kinds and specialty sizes)
By smartcookie in forum Manufacturer NewsReplies: 0Last Post: 06-06-2012, 03:03 PM -
Bargain for someone on eBay
By irving2008 in forum General DiscussionReplies: 2Last Post: 17-07-2010, 09:48 PM -
Is this a bargain?
By irving2008 in forum General DiscussionReplies: 13Last Post: 25-05-2010, 05:53 PM -
Bought myself a lathe.....bargain!!
By HiltonSteve in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 28-12-2009, 05:09 PM
