11-11-2016 #2
Moi aussi! One 7mm reamer arrived today.
Most odd.
11-11-2016 #3
11-11-2016 #4
12-11-2016 #5
They are so cheap that i bought 2 of them . 1x 130mm long and the other one i cut in half for normal jobs. I think it's good enough reason, especially when now i have 2 sets of inserts, one for aluminum and one for steel and cast iron. I think even that the aluminum ones will be good for plastic. Just as a side note that these are side cutters, they can not plunge. and the 12mm one is one flute only
12-11-2016 #6
Be nice to see a pic of them Boyan. Its not uncommon for shanks of that kind of tooling to be soft ish and are often are tough rather than hard, depends on manufacturer and quality but sometimes hard is not good and its promotes resonance rather than curing it. Most cutters like that you can't plunge with. but are perfectly capable of ramping and helical ramping to get the tool down if the machine will allow and take the load.
12-11-2016 #7
The rest of the them arrived today in 2 more packets.
Measured the 10 mm reamer with digital calipers and they were 10.00 mm. I know there is a tolerance those calipers but it seems good so far.
13-11-2016 #8
I've received two so far, in two separate envelopes... What a funny way to run a business!
13-11-2016 #9
Same here, 7mm and 8mm Tried the 8mm as I had an 8mm dowel pin the try in the hole and it's a nice slide in fit.
Hopefully the other will come in the next few days.John S -
13-11-2016 #10
FOR SALE: Pssst. Compressor - grab a bargain!
By Wal in forum Items For SaleReplies: 2Last Post: 15-03-2014, 12:32 AM -
Taps, Dies and Reamers (All kinds and specialty sizes)
By smartcookie in forum Manufacturer NewsReplies: 0Last Post: 06-06-2012, 03:03 PM -
Bargain for someone on eBay
By irving2008 in forum General DiscussionReplies: 2Last Post: 17-07-2010, 09:48 PM -
Is this a bargain?
By irving2008 in forum General DiscussionReplies: 13Last Post: 25-05-2010, 05:53 PM -
Bought myself a lathe.....bargain!!
By HiltonSteve in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 28-12-2009, 05:09 PM
