Thread: Mach3 Software Technical Support
08-11-2016 #12
Good Spot Moray didn't take much notice of the PC and assumed was same PC just fixed. It does look quite new so your probably correct could be 64bit.
Martin if this is the case then you'll need 32bit windows or another PC.
However I must agree with Lee that the Control box is Box of rubbish and with some dodgy wiring and practises. Ie: wiring 2 drives to one Motor output.
It may pay you to upgrade with better Controller that is Ethernet based and done correctly. This will allow to be run on 64bit PC and be much more stable.
new software license required, mach3 or mach4?
By Noplace in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 04-04-2016, 12:00 AM -
NEW MEMBER: Here for technical support!
By JMaack in forum New Member IntroductionsReplies: 0Last Post: 23-04-2015, 05:53 PM -
DeskProto 3D cam software, forum support added!
By Lee Roberts in forum DeskProtoReplies: 0Last Post: 27-01-2014, 03:21 PM -
Mach3 CAD software
By cassius in forum CAD & CAM SoftwareReplies: 5Last Post: 02-07-2012, 12:31 AM -
Buying Mach3 and getting support
By Keith Rumsey in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 18-02-2009, 04:41 PM
