12-11-2016 #1Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
12-11-2016 #2
12-11-2016 #3
And multi line encoder threading. <g>
John S -
12-11-2016 #4
They go hand in hand don't they?, if it's true a 24v based system is less susceptible to noise problems, then it's more professional to use 24v, no ?
I new that was coming, professional industrial grade cnc or professional hobby level cnc?
Yeah but to keep a perspective on things, what other areas of CNC are standardized?
Maybe they havn't had the feedback for those things yet, like i was trying to suggest before, who knows what is to come. Given their rep for support offered, i'm sure they are listening, we just need to let them know maybe?
Not sure i'm bothered about them wanting to sell BOB's, I'm sure there will be benefits to using physically separate units, the option of using your own and the features that you may get with one but dont get with another, for instance...
HANG ON A MO?
The IP-M come's with separate BOB's/cable's anyway so what's the biggy?
Sure the isolation, handy little relay and what ever else they bundle is all nicely tucked away in that pretty little grey box they call the IP-M, but you still have to access that lot with a bob/boc....
SO....WHAT'S YOUR BEEF FAM?....
with having separate units in a UCCNC based system?
How coincidental, just last week I read through the thread where you asked them on the forum what the status of that unit was, i'm pretty sure they said they would get back to it eventually, or words to that effect...
Oooo is that an exclusive lol, looking good so far
The cables you mention are just terminal blocks to make connection easier and not like BOB at all.
Stabilty is all about Layers or more specificly removing layers. BOB's or to be more specific Cheap ones are just Weak Layer which cause trouble.
Don't understand why folks will buy Motion controller for the higher cleaner pulse rates then strangle them by connecting to Cheap BOB with Slow Optos etc.?
It's this and other electrical incompatabilty's that come into play which make multi mixed hardware systems less reliable than one that's been designed and tested to play nice together.
Unfortunatly often this Stabilty comes at premium cost and it really shouldn't because wouldn't cost them much more to add it.!!Last edited by JAZZCNC; 12-11-2016 at 09:37 PM.
12-11-2016 #6
Nobody prevents you from buying a super expensive BOB and use that if you want to and believe it can do better. The BOB I have can pulse fast enough. Besides, the problem is NOT the optos on the inputs but the optos in the stepper driver. If you have crappy driver you have problems, yes, but the pulsing from the motion controller or the cheap BOB is not the problem, the problem is your driver in that case.
Here is a video I just made. My CNC is using the cheap BOBs and the UCCNC with the UC300ETH in this one.
I have also made a similar test with Mach3 and I can't run Mach3 as fast as I can run UCCNC with otherwise everything being the same. Mach3 can't keep up with the acceleration/deceleration, and that's not the fault of the optos in the BOB but Mach3.
12-11-2016 #7
12-11-2016 #8
12-11-2016 #9
I think we are getting cross connected here. What I mean is why don't UC supply connectors ? Pokeys had exactly the same problem as they use IDE's and people were asking for cable kits and Pokeys asked why ?
Simple reason is anyone working in electronics has all these cables, they buy the ends in by the 100's and cable by the 50M reel but they don't understand that the end user has more chance of having a 100 spare M6 nuts and bolts that he does electronic parts.
End result is they put a cabling kit up and I think it costs 19 Euro, or thereabouts.
A piddling amount for the grief that users had to get it.
Don't get me wrong that I'm knocking the product because I'm not. I'm knocking the presentation knowing they could do so much better with hardly any more work.
At the moment the CNC controller world is wide open. We have many looking to upgrade from Mach3 which has been an awesome piece of software. If it wasn't for Art Fenarty on his own then 1,000's of users would not be into CNC at this point. The baton should have been passed to Mach 4 but Brian dropped it big time as evidenced by some of the long time users like Ger21 and Terry Parker switching camps to other controllers.
We are now split between Bert Eddings, Planet CNC, UCCNC and the stand alone Chinese controllers that are showing up.
Thee is not much to choose between the fisrt three although Bert and Planet do have lathe threading up to a point.
However all of them lack this last works out the box scenerio that will put them in front.
Once one of these three does that they will be the new mach3 as controller of choice as regards easy setting up foe beginners and semi- skilled.
Forget the software and electronic guys, they can get anything working if you throw enough time at it.
Your market is the same market that flooded to Art's door.John S -
13-11-2016 #10
Looking in the manual, it does appear that they support multiline encoder threading.
Encoder PPR: This is a numeric value and defines the pulse per revolution of the incremental
encoder which is used to feedback the spindle position in synchronous thread cutting applications.
They just don't have a lathe screenset yet.
Gerry
CNCdrive.com Cheap Servo drives
By BillTodd in forum Marketplace DiscussionReplies: 2Last Post: 13-06-2017, 11:38 AM -
Anyone using CNCdrive products?
By gatesy in forum Machine DiscussionReplies: 20Last Post: 27-12-2015, 11:13 AM -
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM
