    Hi Camera, thanks for the update/share.
    What's the difference in the uc300eth vs the uc400eth?
    Now there is officially a plugin, will you be staying with mach 3 or going back to the UCCNC control software?
    The UC300ETH will accept 24v inputs and can output an analog signal of 0-10v for spindle control. The UC400ETH can only accept 5V inputs and lacks the 0-10v output. There may be other differences. I just built a machine using the UC400ETH and I'm very happy with its speed and reliability but the UC300ETH would have been just as fast and reliable I assume but it would have been simpler to build with. As it was, with the UC400ETH I had to add a 0-10v DAC for converting the PWM signal to the input my VFD required, and also a voltage converter to drop my 24V supply down to 5V for my sensor power/input. The UC400ETH is powered by 24V. It would have been nice if it accepted 24V inputs. I should have planned a little better I guess.
  2. The Following User Says Thank You to 1Jumper10 For This Useful Post:
  3. #2
    Quote Originally Posted by 1Jumper10 View Post
    That is partially incorrect. The UC300, just like the UC400, only accepts 5V input levels and can only be fed by 5VDC. The UC300 has 12V outputs, as well as 0-10V, but the voltages are generated through a step up circuit. None of the UCxxx motion controllers are a replacement for a BOB, and none of them have optical isolators, so a BOB is necessary. To be able to connect 24V to the inputs you need to connect a BOB which can take 24V, otherwise you'd fry the inputs of the UC300ETH or UC300USB.
  4. The Following 2 Users Say Thank You to A_Camera For This Useful Post:
  1. CNCdrive.com Cheap Servo drives
    By BillTodd in forum Marketplace Discussion
    Last Post: 13-06-2017, 11:38 AM
  2. Anyone using CNCdrive products?
    By gatesy in forum Machine Discussion
    Last Post: 27-12-2015, 11:13 AM
  3. Huanyang VFD control plugin for Mach3, USB RS-485
    By JayPunchbuggy in forum Spindles & Drive Motors
    Last Post: 15-05-2013, 08:00 PM
