    The UC300 has 12V outputs, as well as 0-10V
    I don't think it has 12V outputs, because it connects to standard parallel port breakout boards.
    Also, I think the analog voltage varies depending on which motherboard you use, and I don't think it does 0-10V without a breakout board, does it?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    You are correct about the 0-10V output. I was confusing them with the analog inputs.
    The 12V outputs on the analog port are not "outputs", but just 12V.
    The UC300eth also has a 400Khz kernel speed.
    Gerry
    Yes.... well, it is an output, but yes it is just 12V. On when the card is powered up off after power off and in between it outputs 12V on those pins.
  1. CNCdrive.com Cheap Servo drives
    By BillTodd in forum Marketplace Discussion
    Last Post: 13-06-2017, 11:38 AM
  2. Anyone using CNCdrive products?
    By gatesy in forum Machine Discussion
    Last Post: 27-12-2015, 11:13 AM
  3. Huanyang VFD control plugin for Mach3, USB RS-485
    By JayPunchbuggy in forum Spindles & Drive Motors
    Last Post: 15-05-2013, 08:00 PM
