    Newbie question: I purchased a High-Z/S-400T milling machine from CNC Step recently for hobby use. As a test, I'm going to mill a maze into a piece of brass plate. As a prototype step I've cut the same pattern into a piece of perspex. The vertical edges have turned out very well, what I'd also like, though, is to somehow smooth the end of the mill to remove the circular scuffs (see picture below). Can anyone suggest a way of doing that?
    Cutting parameters were: 2 mm two-flute end-mill, tool speed 3,500 RPM, feed rate 4 mm/second, plunge rate 0.3 mm/second and pass depth 0.3 mm (so 10 passes to make the 3 mm depth above).
    Rob
    Tram the spindle as good as you can.
    Use corner rounded end mills.
    Get a more rigid machine.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  3. The Following User Says Thank You to Ger21 For This Useful Post:
    Thanks for the swift response.
    Corner rounded end mills sounds good. I'm afraid I need to ask what you meant by "tram the spindle" though...?
    That cut was made over a 9 hour period with no return to reference, so I think the registration, which I guess is the derivative of rigidity, is pretty good. Anyway, I'm not forking out more than UKP 5k for a machine!
    Rob
  5. #4
    You need to use a one flute end mill, the 2 flute leave more trace on the end of tool. Especially on perspex. the rigidity has nothing to do with that, the walls are clean, so no vibrations.... 3500 rpm for a 2mm flute and 4mm feed rate is to low, 8000 rpm and up is 🆗
    Sended by my tapatalk
  6. The Following User Says Thank You to Merlin201314 For This Useful Post:
  7. #5
    Ah, good information, this is the kind of thing I will learn by experience I expect. I've been searching on the web for something that will tell me the recommended tool-speed/feed-rate/pass-depth for a given material/tool-diameter/number-of-flutes (all in metric please!). Is there such a thing? I end up doing some part of the calculation manually when it seems trivial to create a proper calculator for it.
  8. #6
    Lives in Plymouth, United Kingdom. Last Activity: 23 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    There are tools like HSMadvisor and G-Wizard, which give you a free trial and then you pay. I think that there might be some free online tools as well, but I haven't used them.
  9. The Following User Says Thank You to Neale For This Useful Post:
  10. #7
    I was originally looking for web-based calculators but if I have to download and/or pay for an app then so be it. I'll go look...
  11. #8
    Try this one. I couldn't remember the name just now.
  12. The Following User Says Thank You to Neale For This Useful Post:
  1. Smooth finish with v bit on mdf
    By Skydeals in forum General Discussion
    Last Post: 16-10-2015, 10:28 PM
  2. Replies: 4
    Last Post: 21-01-2014, 11:00 PM
  3. Creating .TAP files in Mach3
    By Ahmed in forum Artsoft Mach (3 & 4)
    Last Post: 23-11-2013, 09:51 AM
  4. FOR SALE: milling slot cutter 20mm new for sale
    By chalfontcrew in forum Items For Sale
    Last Post: 04-02-2013, 12:18 AM
  5. Creating Local group/club???
    By m.marino in forum General Discussion
    Last Post: 02-07-2010, 11:03 AM
