  1. #28
    No, I'm picking up a compressor tomorrow and hope to use Boyan Silyavski's guidance to make myself an air blower. Maybe I'm just asking too much, making such a long slot-cut without cooling/blowing? I moved away from carbide to HSS because I could run at a lower speed (and hence reduce the heating effect) but it doesn't seem to have been a sufficient reduction. I think I'm going to try again with the same settings but reducing the feed rate right down, to 2 mm/second. I'll keep the vacuum handy and give it a suck every so often. I'll also order some more bits, 2 flute this time, and a lot more brass. Gonna get this right eventually...
    Thanks Rob,
    Rob.
  1. Smooth finish with v bit on mdf
    By Skydeals in forum General Discussion
    Last Post: 16-10-2015, 10:28 PM
  2. Replies: 4
    Last Post: 21-01-2014, 11:00 PM
  3. Creating .TAP files in Mach3
    By Ahmed in forum Artsoft Mach (3 & 4)
    Last Post: 23-11-2013, 09:51 AM
  4. FOR SALE: milling slot cutter 20mm new for sale
    By chalfontcrew in forum Items For Sale
    Last Post: 04-02-2013, 12:18 AM
  5. Creating Local group/club???
    By m.marino in forum General Discussion
    Last Post: 02-07-2010, 11:03 AM
