Thread: Cutting path questions
12-11-2016 #2
Geometry is the usual issue, translating between packages can result in the odd "Funny"
Check version compatibility - do you need to "save as" an earlier version of .dwg for the CAM package to corectly interpret the geometry?
Having the imported object as simple as possible will also improve your chances.
That's about all I've got ;-)
FOR SALE: Bridgport EZ path s
By compositepro in forum Items For SaleReplies: 1Last Post: 08-10-2016, 06:06 PM -
Code to plunge Z gradually and then retract along length of a profile path.
By Wal in forum Programmers CornerReplies: 22Last Post: 18-11-2015, 12:53 PM -
Going down the correct path, Amadeal AMD25LV mill conversion to CNC
By StevenT in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 20-07-2014, 08:23 AM -
Romi EZ-Path S Lathe crt replacement
By Nemo1966 in forum MonitorsReplies: 5Last Post: 07-10-2013, 04:25 PM -
in calculating the tool path
By Grumpy Mike in forum Programmers CornerReplies: 17Last Post: 31-07-2010, 10:18 AM
