Page 6 of 6 FirstFirst ... 456
  1. Anyone that is running on single phase
    What did you do re coolant pump?
    Swap motor? Capacitor a phase to run single phase? Or install a vfd?
  2. #52
  3. #53
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    My Triac was a single phase machine, so the coolant pump wasn't an issue.
    A new pump would probably be the most reliable long term option though.
  4. #54
    my triac is a single phase version and when the coolant pump when i popped the above striaght in. check the length though as cant remember what it is
  5. Ok - re coolant pump
    Seems to work fine as single phase if wired delta- using just L & N
    Using a run capacitor of 8uf. Starts fine, runs quiet and straight up to speed
    :-) only had to cut a small notch in the wiring box to bring the capacitor cables out of.
  6. https://youtu.be/1uJpm7IN7-M
    shows a quick explanation of converting suds motor to single phase.
    note the spin direction was wrong so i reversed it by moving the wires around- correct in video
  1. Denford Triac - Help
    By mikeadams1985 in forum Denford Mills
    Last Post: 12-01-2017, 10:06 AM
  2. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  3. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  4. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
