Thread: Help with haas vf0e
Yes,_check_the_PSU_output_with_the_pins_shorted_th en_remove_shorting_pin,_disconnect_mains_and_conne ct._Then_test.
Damn this reply box behaviour, now it's recognising spaces but if I insert them higher up the reply it parses them as line feeds and initially ignored them entirely!
17-11-2016 #2
17-11-2016 #3
17-11-2016 #4
If your PSU doesn't have all the right voltages it isn't the right PSU for the job, you could add a separate -5v fairly easily, but have you asked the manufacturer how much for the correct PSU for the job?
17-11-2016 #5
I think you need one of the older type ie AT not ATX http://www.ebay.co.uk/itm/AT-PSU-WOR...-/142163387623
see this at the bottom of the page https://en.wikipedia.org/wiki/Power_...nit_(computer)Last edited by Clive S; 17-11-2016 at 02:23 PM.
17-11-2016 #6
17-11-2016 #7
Either the video card, or the video card is getting junk data.
You're probably better speaking to your board repairers, as now you know what the main problem was, and the machine is now doing something, it may help them track down what has been damaged.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
17-11-2016 #8
17-11-2016 #9..Clive
17-11-2016 #10
Haas Hl2 lathe assitance S70 area
By MAW in forum Lathes, Lathe Rebuilding & ConversionsReplies: 2Last Post: 05-09-2016, 08:09 AM -
Haas mini mill spindle ramp up time
By Hellfire in forum Machine DiscussionReplies: 2Last Post: 16-05-2016, 10:33 AM -
Haas vf-0e 1995
By jackpat in forum Machine DiscussionReplies: 0Last Post: 13-05-2016, 11:18 AM
