    Just to throw something else into the mix... I contacted Fehlmann (the makers of my mill) and asked them what they used on the modern equivalent of my machine. They now use Omron "Smartstep" servo motors (R88M-G40030h) with a nominal torque of 1.3Nm and a momentary torque of 3.6Nm. 2.6A mains (200v ac) powered driver.
    I'm wondering again whether those Leadshine 3ph Nema23 2Nm closed loop steppers wouldn't do the job or is the torque characteristic for a servo very much different to a stepper?
    Quote Originally Posted by Agathon View Post
    Very different.!!
    The 1.3Nm is continous meaning thats what you'll get at full motor speed probably 3000rpm. The 3.6Nm is Peak torque which the drive/Motor can handle for limited period of seconds which is often enough to handle high enertia or heavy starting loads. Under heavy loads ie: cutting it will handle anywhere between 1.3nm & 3.6nm for limited periods depending on loads.
    Throw into the Mix that because Rpm is often much more than required there will ratio applied so torque actually increases.
    Stepper rating on the other hand measured at ZERO RPM and starts to drop as the Rpm's increase. Slowly at first up until point of the Speed curve where it starts to drop quickly untill full motors coils reach full saturation and motor stalls. On 34 motor the speed curve will be aprox 900rpm depending on inductance and voltage used. There'll be little to no torque at 1500rpm.
    This is why inductance and Voltage is so important to the speed you get from steppers. Also you throw how stepper is wired into the mix and it can change again.?
    If wired parallel you'll get torque higher up the rpm range but less lower down for set voltage. If wired series you'll get pretty much the opposite, Higher torque lower down rpm range but motor will reach saturation much sooner for the same voltage so lower RPM.
    Most 34 motors are 4 wire series wound motors and to get any decent speed from them requires High Voltage. Often larger Nm 34's are run with mains voltage drives.
    Now for mill you won't require high rpm's so series wound is often Ok. Nema 23 motors often come with 8 wires and can be wired series or parallel. But the same applies in that higher voltage is required for same rpm if series wound.
    So in nut shell if they Fit 1.3nm Servos then 2Nm Nema 23 Stepper isn't going to cut it really.
    Very clear reply - thanks.
    OK, so just to confuse myself more I've tried to fill out the Excel motor calculator here - http://www.mycncuk.com/threads/1524-...otor-do-I-need
    I've attached the calculation with what I think are generous values using the Leadshine 3ph 2Nm motors LS2NmMotorCalcs.xls
    This seems to look OK, but have I missed something - are my estimates as to load mass and table speed too low? The 3ph 2Nm Leadshine motors have an encouragingly flat torque curve at less than 360rpm - Click image for larger version.
    If I go for conventional steppers I'll go with the AM822 drivers, but what size motor? The old steppers have a surprisingly small shaft (3/8") so Nema34s with 14mm shaft are a bit of nuisance. I see Nema23 3Nm motors with 10mm shafts - http://r.ebay.com/KuT9Ez - Are these big enough though?
    Sorry for all the questions.
    Just to give some idea of the sort of machine - here's a (bad) photo:Click image for larger version.
    As you can see, it's a kind of mill-drill. But don't be fooled, this thing is a beast weighing in at about a tonne. The table weighs around 150kg - hence my 100kg load per axis estimate. The motors drive the ball-screws directly.
  5. #4
    Lives in East Lothian, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    My gut instinct for a machine like that with direct drive steppers, would be something in the 4Nm range to give plenty safety margin.
    I think personally I'd consider altering things to use a belt drive with some Nema23 steppers, which should give you better performance. With big Nema34 motors, for best performance you've really got to use high voltage drivers, but you're then still limited at torque drops of quite quickly with big steppers.
  6. #5
    Thanks. I had considered driving via a belt just in order to make the machine more compact. Would you gear up in order to increase the speed of the ball-screw relative to the stepper?
  7. #6
    Opposite way!
    You want to decrease speed of the ballscrew in relation to the stepper, so you get more torque at the screw. Somewhere around a 2:1 ratio would be a good starting point.
    Try running some figures through the spreadsheet to see what kind of speeds you can get with different ratios, while still having usable torque to handle the cutting forces.
  8. #7
    Opposite way!
    OK, that's certainly how I would have dealt with torque issues with a conventional motor, but I thought the whole point was that torque went down as speed increases. I see that gearing down, by say 1:2 would give twice the torque, but getting the speed up to 1800 mm/min (900rpm for the motor) for rapids will mean that the motor is well outside it's optimum torque region. Or is it the case that in practice this wouldn't be an issue?
  9. #8
    Ok well first need to check if the machine is fitted with Ballscrews not just lead screws which you are calling Ballscrews.?
    If ballscrews then 3 or 4Nm Nema 23 motors will probably work. I've fitted loads of Both 3 & 4nm motors and to be honest see very little difference between them in performance terms so wouldn't stress over which to use. The Key is buying ones with Low inductance. No higher than 4mh ideally closer to 3mh.
    These are better motor and will fit your needs.
    https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
    If you speak to them Don't Let them Bullshit you into believeing there drives are as good or better than Leadshine AM or EM they are not.!
  10. #9
    This maybe your Lucky day my friend.?
    Just remembered somewhere in box I've got some motors and sure enough there was.!! And guess what they are 2 x Brand New 34's with 10mm shaft 8 wire motors model number FL86STH65-2808A-H. Think about 3.5Nm but would need to dig out motor data sheet.
    Also got another 34 4 wire motor with 12mm shaft which is around 4Nm I think. SY85STH65-5904B.
    Drop me PM if your interested.
  11. #10
    Great, I'll pm you.
  1. Electric motorbike racing
    By Jonathan in forum General Discussion
    Last Post: 16-08-2016, 03:28 PM
  2. Need assistance with electric enclosure please (CSMIO/AC Contactor issue)
    By Noplace in forum Electronic Project Building
    Last Post: 22-01-2016, 12:09 PM
  3. FOR SALE: 240v decent electric filter
    By DrNik in forum Items For Sale
    Last Post: 16-03-2015, 12:30 PM
  4. Recommend a superior stepper motor driver IC to you.
    By lihaijiang in forum Motor Drivers & Controllers
    Last Post: 16-12-2011, 09:11 AM
  5. FOR SALE: Metabo 710W 230V Electric spindle, stepper motors, Tr nuts 20x4
    By Vladimir_MD in forum Items For Sale
    Last Post: 09-04-2010, 05:24 PM
