Ok well lets work it out for you. I'll assume Mod1 pinion. So the Diametric pitch (basicly diameter) will be 20mm because Mod1 =1mm times the #teeth.
Apply \pi and the affective pitch is 62.832mm which is huge and why you need ratio. So then divided by the ratio to give pitch of 20.95mm per rev.
Working on motors full step value then Full step resolution will be 20.95/200=0.104mm per Step.
Now this is the smallest amount you'll move if the drives where set to Full step. Which you won't want to do otherwsie they'll run like bag of marbles. But take it thats your worst case scenerio.
In real use you'll have the drives set to something like 800 or 1600 micro steps. Going above this is pretty much wasted and just stress the system for very little gain.
So Best case will 20.95 / 1600 = 0.013mm thou don't get excited because you won't get that in reality but will fall some where between 0.1 and 0.01 which i'm sure you'll be pleased with.
But again don't too giddy because thats only resolution and it means nothing in accuracy terms if the machine bends like banana.!!
Now you'll want to know the speed you can expect.? So lets work on 900rpm which is realistic figure for stepper using R&P provided run on enough volts. (60-70v)
20.95mm x 900rpm = 18855mm/min or 18.85mtr/min which is just about spot on for decent sized plasma machine.! . . . . Well Done . .Lol
Edit: Opp's I forgot the ratio.!!
So it's 20.95 x (900/3) = 6285mm/min or 6.3mtr/min which is still ok for cutting but on the slow side for rapids on large machine.
In practise provided all is setup well and correct voltages etc I'd estimate 8mtr/min or more will be quite do-able.Last edited by JAZZCNC; 18-11-2016 at 09:11 PM.
28-11-2016 #2
HELP!!!!!!
im just coming to the stage to order my pulleys for reduction on the x and y axis.......dean kindly worked out the 3-1 reduction with mod1 rack and pinion.........
iv actualy used mod1.5 with a 24t pinion spur gear..............if i order t5 60 tooth and 15 tooth will this be ok to get me back near the mod1 calculation in the above post???
28-11-2016 #3
It's easy to work out if you know the Dp (Diametric pitch) of the pinion which for 24T Mod1.5 is 36mm. Then times this by pi to give the Linear pitch before ratio which in this case is 113mm.
Now you can work out ratio you'll need to give the desired linear Pitch. 15t/60t will give 4:1 ratio so 113 / 4 = 28.25mm. For Plasma this would work ok.
Ps: Word of warning before ordering make sure 15t pulley will fit your motor shaft because there won't be lot of pulley left for grub screws etc after it's bored.Last edited by JAZZCNC; 28-11-2016 at 05:30 PM.
10-12-2016 #4
hi, just a few questions. is 100mm deep enough for a water table? and is there a prefered spacing for the slats??
many thanks
building MK2 with rack and pinion
By universally in forum Machine DiscussionReplies: 3Last Post: 23-12-2015, 01:54 PM -
Ballscrews or rack and pinion? What module of rack and pinion is the best?
By masinecc in forum Rack & Pinion SystemsReplies: 7Last Post: 14-04-2015, 02:16 PM -
rack and pinion
By D-man in forum Rack & Pinion SystemsReplies: 9Last Post: 20-10-2014, 10:42 AM -
chai & rack and pinion
By kingcreaky in forum General DiscussionReplies: 3Last Post: 30-06-2014, 01:27 PM -
Rack and Pinion
By pmcb1011 in forum Rack & Pinion SystemsReplies: 3Last Post: 31-05-2011, 11:55 AM
