HELP!!!!!!
im just coming to the stage to order my pulleys for reduction on the x and y axis.......dean kindly worked out the 3-1 reduction with mod1 rack and pinion.........
iv actualy used mod1.5 with a 24t pinion spur gear..............if i order t5 60 tooth and 15 tooth will this be ok to get me back near the mod1 calculation in the above post???
28-11-2016 #2
It's easy to work out if you know the Dp (Diametric pitch) of the pinion which for 24T Mod1.5 is 36mm. Then times this by pi to give the Linear pitch before ratio which in this case is 113mm.
Now you can work out ratio you'll need to give the desired linear Pitch. 15t/60t will give 4:1 ratio so 113 / 4 = 28.25mm. For Plasma this would work ok.
Ps: Word of warning before ordering make sure 15t pulley will fit your motor shaft because there won't be lot of pulley left for grub screws etc after it's bored.Last edited by JAZZCNC; 28-11-2016 at 05:30 PM.
10-12-2016 #3
hi, just a few questions. is 100mm deep enough for a water table? and is there a prefered spacing for the slats??
many thanks
building MK2 with rack and pinion
By universally in forum Machine DiscussionReplies: 3Last Post: 23-12-2015, 01:54 PM -
Ballscrews or rack and pinion? What module of rack and pinion is the best?
By masinecc in forum Rack & Pinion SystemsReplies: 7Last Post: 14-04-2015, 02:16 PM -
rack and pinion
By D-man in forum Rack & Pinion SystemsReplies: 9Last Post: 20-10-2014, 10:42 AM -
chai & rack and pinion
By kingcreaky in forum General DiscussionReplies: 3Last Post: 30-06-2014, 01:27 PM -
Rack and Pinion
By pmcb1011 in forum Rack & Pinion SystemsReplies: 3Last Post: 31-05-2011, 11:55 AM
