Page 4 of 8 FirstFirst ... 23456 ... LastLast
  1. #31
    loving this thread. keep the photos coming warwick.
  2. #32
    evening chaps....iv built the one side of the y axis drive.....not sure if iv got the pivot on the right place? there is enough travel to disingage from the rack if needed..Click image for larger version.
ID:	20329Click image for larger version.
ID:	20330Click image for larger version.
ID:	20331Click image for larger version.
ID:	20332Click image for larger version.
    the shape of the gearbox is awful,but ill make some more when the tables up and running, iv had to run the steppers inboard because of the x axis moving off the table.......
  3. Very envious of the space you have in your workshop and that enormous welder! Looking good, I quite like the weird looking gearbox!! Subscribed.
  4. #34
    ned's Avatar
    Lives in dublin, Ireland. Last Activity: 18-12-2023 Has been a member for 8-9 years. Has a total post count of 23. Received thanks 1 times, giving thanks to others 0 times.
    good progress. the gearbox might look more in keeping with the machine if it were more angular, like below. Its functional though, who cares, it works.
  5. #35
    managed to get the rack bolted upto the gantry tonight, im going to re design the y axis gearboxes because..theres to much pressure on the rack and pinion gear because the pivot it to close...i can get 3m cut on the y axis..and it looks awful...
    photos of the rack bolted to the gantry
ID:	20344Click image for larger version.
  6. #36
    How about turning the motor the other way up so that it can't get fowled from below
  7. #37
    hi, a few more pics...the first is the end of my shed that not many see ....the next picsare of the cable drag chain
ID:	20392Click image for larger version.
ID:	20393Click image for larger version.
ID:	20394Click image for larger version.
ID:	20395Click image for larger version.
ID:	20396Click image for larger version.
ID:	20397Click image for larger version.
ID:	20398Click image for larger version.
ID:	20399Click image for larger version.
ID:	20400Click image for larger version.
  8. #38
    this is the final design for the y axis drive,the motors will be tucked away under the table, it doesnt take alot of spring pressure to hold the pinion into the rack.i can now get full travel accross the whole table...
ID:	20414Click image for larger version.
ID:	20415Click image for larger version.
ID:	20416Click image for larger version.
ID:	20417Click image for larger version.
  9. #39
    iv managed to finish the reduction gearboxes and mount them today,have ordered the cable so i'll be wiring very soon!!
ID:	20469Click image for larger version.
  10. #40
    iv got the cable drag chain carrier fabbed up,just the ends of the x axis linear rails to support and im finished the fabricating...
ID:	20501Click image for larger version.
  1. Have you built your own CNC plasma table ?
    By adscnc in forum Opportunities Available & Sought
    Last Post: 15-09-2016, 02:13 PM
  2. Plasma table 4x4 kit and electronics
    By whensparksfly in forum Items Wanted
    Last Post: 27-02-2016, 01:37 PM
  3. 10' x 5' Plasma table design
    By Kerryfisher in forum Plasma Table Machines
    Last Post: 20-02-2013, 09:28 AM
  4. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
